Strange gauge problem
I have a strange issue going on with one of my gauges. I have three on my pillar, prosport volts, oil preassure, boost. My boost gauge used to work fine and now it stays pegged at vac max. I thought maybe vac line. Boost works when I blow into tube with car in accessort but as soon as car starts it pegs. Now I even disconnected the sending unit totally and the gauge only pegs when car starts, but with key in acc it stays at 0. I checked the wiring and it's all hooked up same way it always has when it worked perfectly.*
I am currently running a prosport boost gauge and this happened to me about 4 months back, i just had to change the boost sender and it fixed the problem right away, i think i paid like $20 for a new one from prosport
None of my prosport gauges work correctly when car is running, but work fine when in accessory mode. How can that be? They used to work fine. I didn't install them previous owner did.
pitbulllove2003
Dec 28, 2014 04:40 PM
OfaceGrimmins
30
Nov 15, 2011 02:11 PM
