All three ACD lights on when the car is hot?
Old Jun 9, 2011 | 02:53 PM
Talon's Avatar
Now that the weather is getting hotter, I've noticed when the car sits outside in the sun, all three ACD lights come on when I'm diving. Engine temp has nothing to do with it, just when it sits in the sun (sits in a garage at home and it's not an issue). This started happening like a month ago.
It doesn't seem to be effecting the performance of the car, and if I hit the ACD button it will change (I confirm this next time I start up the car after it's been in the garage).
I was going to try and reset the ECU but haven't done it yet. Anyone else have this? Easy way to fix it? It's an 05 if that matters...
Old Jun 9, 2011 | 03:31 PM
Vivid Racing's Avatar
Get the pump checked, sounds like that might be the issue.
Old Jun 9, 2011 | 03:39 PM
Talon's Avatar
What pump?
Old Jun 9, 2011 | 03:46 PM
The ACD pump
Here's a good read if you not sure what an ACD Pump is
https://www.evolutionm.net/forums/ev...everybody.html
Old Jun 9, 2011 | 03:55 PM
dinoz1980's Avatar
check ACD has oil some times when low oil the 3 lights go on
Old Jun 9, 2011 | 05:18 PM
Talon's Avatar
I'll start there, thanks.
Does it matter it only happens when the car has sat outside in the sun for some time?
Old Jun 9, 2011 | 05:38 PM
Hard to tell
Old Jun 9, 2011 | 05:40 PM
deadmeat's Avatar
I had the same exact problem when my pump started to go out. Mitsu replaced it under warranty.
Old Jun 9, 2011 | 08:04 PM
tha_yen's Avatar
I actually have seen this with my car the past two days where we were in the 90s...not sure how that is throwing it off, but today we were in the 60s and the lights didn't all come on like they did the previous days.
Old Jun 9, 2011 | 08:09 PM
vmrevo9's Avatar
Veteran: Air Force
could it be that the pump is starting to go out and the hotter temp is making it fail? so pretty much i wonder if the pump is over heating?
Old Jun 9, 2011 | 08:10 PM
EVOMIZ's Avatar
Does anyone repair the pump?
Old Jun 9, 2011 | 11:26 PM
fightex's Avatar
check this thread: https://www.evolutionm.net/forums/ev...-searched.html
Quote:
hi i will try to help out, 3 acd lights means there is a fault with the acd or the abs, fault codes are stored in the acd ecu,
get a paper clip and use it to bridge pins 1&4 on your obd
(diagnostics plug) as you sit in the driver seat its in front of your right knee,
when the paper clip is in place turn the key on (dont start the car)
if there are no faults codes the 3 acd lights will flash rapidly.
and if there is fault codes, the 3 lights will flash slower
for example fault code 65
there will be 6 long flashes slight pause followed by 5 short flashes,
simply count the long flashes as 10 6x10
and the short flashes as 1 5x1 = 65
there may be more than one code.
hopes this helps, frank
Quote:
here are the acd/abs fault codes
12 power supply open or short circuit
21 fr right wheel speed sensor open or short circuit
22 fr left wheel speed sensor open or short circuit
23 rear right wheel speed sensor open or short circuit
24 rear left wheel speed sensor open or short circuit
25 wrong diam tyre
26 faulty wheel speed sensor
31 steer sensor system(st1,st2,stn)open circuit
32 steer sensor stn short circuit
33 steer sensor stn system
34 steer system st1 st2 short circuit
41 tps open or short circuit
51 longitudinal acc sensor open or short circuit
52 longitudinal acc sensor
56 lateral acc sensor open or short circuit
61 stop lamp switch system open-circuit
65 abs monitor system open or short circuit
71 proportioning valve system open or short circuit
72 directional control valve right open or short circuit
73 directional control valve left open or short circuit
81 ayc relay system open or short circuit
82 electric pump system
83 electric pump system
For those of you with a Tactrix cable and EvoScan the first part is not needed per say. Thanks to frankmc for the info.
Old Jun 10, 2011 | 05:49 AM
killerpenguin21's Avatar
the fluid used is ATF.
just like other lubricants in it has a temp limit. what ive noticed on my car, is that above 85 degrees when the lights come on the fluid level in the reservoir is much lower due to the system sucking in more fluid to build pressure.
i am not convinced this points to a fault in the pump, since all the way up to 80 degrees ambient temp i can drive all day and have no issue.
im considering dropping it at the dealer so they can do a pressure check, but i want it done under warranty which of course might be a fight.
my fluid has 50k miles on it so it may be worth a shot to do a bleed and change, and im also still trying to find someone who may have used the amsoil sp3 equivalent fluid, which im sure is more heat resistant.
Old Jun 10, 2011 | 09:11 AM
datuck's Avatar
my car had all three lights on and I got an oil change. the issue went away. :/
Old Jun 10, 2011 | 11:22 AM
Talon's Avatar
Hmmm, so it seems like it could be anything from the fluid needing topped off to a bad pump (which is like 2k according to another post).
Awesome…
honda-guy
14
Dec 28, 2015 04:49 AM
ahr4156
24
Jun 28, 2012 09:45 AM
Deathevn
Feb 21, 2010 08:06 PM
Meevo
18
Dec 12, 2009 03:23 PM
zeus1
19
Jun 14, 2009 09:32 PM
