hallman boost controller issues
Old Jul 3, 2011 | 12:35 PM
chris89's Avatar
I was running 14 to 15 psi I was told it would prolly be the boost selonoid to hook up a bc and it bring up to stock boost. My only miss are a full turbo back and air filter
Old Jul 3, 2011 | 12:41 PM
chris89's Avatar
One line is teed into the bov to intake manifold and the other is goin straight to wastegate. I brought the boost up to 17 and it just feels like crap it doesn't pull or anything
Old Jul 3, 2011 | 12:44 PM
chinto's Avatar
lets try this from the start.
did you have the intake and exaust on and it working correctly? (19 ish psi boost)
if the mbc is installed correctly now if you turn it up will it boost over 15 psi?
Old Jul 3, 2011 | 12:46 PM
chinto's Avatar
did you cap off the other nipples on the turbo and on the intake?
Old Jul 4, 2011 | 07:08 AM
chris89's Avatar
Before I decided to install the boost controller I noticed that there was a air bleeder installed and I coyldnt undrstand y I was hitting 25 psi but there was lag the air bleeder was running to wasgate I removed it and I was only hitting 14 to 15 psi but performance and spool was a lot better just not ebough boost so j went and got the hallman it boosts 20 psi but I think there is a leak so I'm gonna take everything apart make sure everything is tight and try it again
Ultimate CC
57
Sep 27, 2015 10:08 AM
bumpnz
Oct 29, 2013 06:00 PM
speedmaster747
Nov 2, 2009 08:11 AM
drano7823
May 7, 2008 01:41 PM
2highpsi
Apr 21, 2008 07:10 AM
