Trouble getting shifter into 1st gear and Reverse.. Clutch or trans?
Old Aug 19, 2011 | 09:57 PM
GSX 911's Avatar
2006 Evo having trouble getting into first gear and reverse. You have to almost force it in. Does not go in easily 90% of the time.
Ive had people tell me its the trans, or the clutch, or the clutch fork.. Which one is it most likely?? Any help is appreciated.
Old Aug 19, 2011 | 10:01 PM
sho669's Avatar
Clutch needs adjustment, sounds like it's dragging, pretty common.
Old Aug 19, 2011 | 10:19 PM
polish_pounder's Avatar
how do u adjust?
Old Aug 19, 2011 | 11:50 PM
Hendrixmx's Avatar
https://www.evolutionm.net/forums/ev...djustment.html
Old Aug 20, 2011 | 02:33 PM
Raistlin's Avatar
I get this from time to time myself.
Which direction do you adjust if a clutch is dragging?
Old Aug 20, 2011 | 02:52 PM
Craig King's Avatar
Do you happen to have an Exedy Twin?
Old Aug 20, 2011 | 06:29 PM
GSX 911's Avatar
It is a twin disc, but im not sure what brand it is.
Old Aug 20, 2011 | 08:56 PM
ProPilot04's Avatar
In the owners manual it specifically says regarding first gear that if its difficult to get into, you should pump the clutch pedal.
Happens on my 9 all the time. Pump the clutch twice and see if it goes in smooth?
Old Aug 20, 2011 | 09:58 PM
sho669's Avatar
usually you make the rod longer, the how to listed is pretty good.
There was also a video done by jacks transmissions on clutch adjusting that was well done.
http://www.youtube.com/watch?v=vYJxQyjIhUw
Old Aug 20, 2011 | 11:04 PM
bigben's Avatar
Try this as well: http://www.evomoto.com/tech_articles..._article_id=17
I've had my Evo for just over 3 years now, and I've always had notchy shifting. I thought the tranny was having synchro problems, until I PROPERLY bled the clutch line exactly how the link above said to do it. It shifts so much better now that it fully disengages between shifts!
Old Aug 21, 2011 | 06:32 AM
Raistlin's Avatar
I usually do pump the clutch a few times and it takes care of it.
Yeah the how to is pretty simple just was not sure which way to take the rod.
Old Aug 22, 2011 | 06:06 PM
FERNO's Avatar
Subscribed.
I get a small grind going into reverse when cold. I'm going to look in to the methods above.
2slowEVO8
Sep 19, 2021 02:14 PM
nor11384
15
Sep 15, 2019 01:58 PM
CaptainSquirts
May 17, 2016 08:35 PM
GSX 911
Apr 7, 2014 05:54 PM
Braden71790
Apr 7, 2011 12:51 PM
