Lifter noise questions
Old Nov 26, 2011 | 07:10 AM
Brent_si's Avatar
I know this has been covered alot but I just wanted to get some opinions. So did the first oil change since I got my evo yesterday. after i changed it it started ticking kind of loud. This is what i heard. The oil level has to be perfect or it will create air bubbles in the valve cushions and cause ticking. Car does have hks 272's. Anyone heard anything different?
Old Nov 26, 2011 | 07:17 AM
wizzo 8's Avatar
Did it tick only at start up and then go away? If its still ticking you will have to remove the noisy lifter to clean it out. Ticking from the lifters doesn't damage anything but can get annoying
Old Nov 26, 2011 | 07:26 AM
Brent_si's Avatar
No it didn't go away. I honestly didn't hear it on start up. I started driving it and noticed it a few miles later. It does it alot a idle but it gets faint after that. Still idles perfect even with my big cams. The previous owner said it goes away after a while and has done it when oil is changed if you are a bit low on oil but wont go away if oil level is to high... He said there is a thread about it but I cant find it. Anyone seen it before?
Old Nov 26, 2011 | 07:38 AM
wizzo 8's Avatar
https://www.evolutionm.net/forums/ev...er-change.html
Old Nov 26, 2011 | 07:47 AM
Brent_si's Avatar
Im talking about the oil change. not changing the lifters. like i said i was told the oil level has to be perfect or it will tick.
Old Nov 26, 2011 | 07:50 AM
wizzo 8's Avatar
That doesnt make sense. As long as you have oil pressure it doesnt matter on the oil level. Unless its very low and you take corners fast, brake hard or launch hard causing the oil pickup to starve for oil. In this case the oil wouldnt make it to the lifters and cause them to tick untill it gets oil pressure again.
Old Nov 26, 2011 | 07:59 AM
Brent_si's Avatar
I thought it sounded odd to but he said there is a thread on here about it. He swears it goes away after a week or so if oil level is correct. It is kinda of loud but as long as its nothing serious im good.
Old Nov 26, 2011 | 08:03 AM
wizzo 8's Avatar
It probably does go away after a week but I dont think oil level has anything to do with it. I dont remember ever seeing a thread on this. Lets see what other people say about this.
Old Nov 26, 2011 | 09:37 AM
Fastone_evo6's Avatar
come on man , think logic ,
If the car did not tick , when you got it , and you change your oil , and the oil is the correct amount , and you se the corrent amount on the oil stick ,
there is no way it would be your berings in the enginge , so relax.
This cars are very sisitiv of what kind of oil you use,, I Use Motul 300V 5W40W racing oil full syntetic in winter , and 10/50 OKQ8 F1 full synteic ,, oil in the summer ,
Im pritty sure its only a lifter that has jamed , and that is what will start your ticking noise,
My evo 6 tme did the same thing i change to lifter whit 3mm hole , called JANSON LIFTERS . google it , theay are realy good ,
after the change my car stared to tick like hell ,, wo i was whinking what the **** , but is normal , after som miles of driveing when the oil got in every little spring and hole , the engine is now quiet.
so please relax,
worst case you will have to change your lifters , and thats done in 2hrs ,
Old Nov 26, 2011 | 10:32 AM
barneyb's Avatar
Any member can post. Some have knowledge, some don't.
In a long thread, somewhere in it you will probably come upon the correct answer. The rest you need to filter out.
Old Nov 26, 2011 | 11:50 AM
Brent_si's Avatar
I was worried when I heard it but honestly not now. I may switch to amsoil next oil change to see if it makes any difference.
Old Nov 26, 2011 | 05:46 PM
5speedwtneed's Avatar
Fresh oil is probably thinner. And as it gets used it thickens up which hides the tick.
Just my .02
BrownParticles
May 18, 2020 09:17 AM
DanielM
Apr 13, 2016 02:13 PM
Spec-Ops1
E85 / Ethanol
15
Jul 30, 2015 03:52 PM
Evolution 8 MR
Dec 1, 2012 11:53 AM
razo
Lancer Troubleshooting
Mar 15, 2008 01:41 PM
