battery relocation kit?? suggestions?
Old Jun 6, 2014 | 12:39 PM
  #31
Svendiesel's Avatar
hahaha ^
Whats the consensus on Gauge, 1 or 2?
Old Jun 8, 2014 | 05:15 PM
  #32
TommiM's Avatar
Fwiw, Ive taken the tape off the oem ground and found the connection to the terminal was really crappy. I didn't even reuse that when I relocated mine. Im running 0 gauge power from the engine bay to the trunk, and 2 gauge ground going from the battery to a ground right near the rear seat. Im using a Miata size battery, 320cca iirc. have aftermarket cams and springs ( if that really matters), and car starts up within 2 cranks usually.
I wouldn't really buy a 'kit'. this is a fairly straightforward project with the only tough part about it is where you want your battery and what battery you want to use. Cables, I recommend 0 gauge. A high quality 0 guage cable will be more flexible and weigh about the same as a cheap 2 gauge, from experience of having 2 gauge at first.
Old Jun 9, 2014 | 06:09 AM
  #33
luvboost's Avatar
The reason I bought a kit is the last one I made wasn't the best and the kits aren't much more or a clean look and an enclosed battery. So my second evo had a kit and it was better imo. I used 0 gauge as well if I can recall.
BaLListic_EVO
Aug 7, 2018 10:22 PM
Evo2H8
Apr 11, 2014 10:03 PM
steven121
Nov 17, 2013 06:37 AM
sith_killer_99
Sep 6, 2012 12:34 PM
outlaws69
Northwest Region
26
Nov 3, 2010 08:42 PM
