2 different readings!
Old Jan 1, 2012 | 07:02 AM
Blue_05EVO's Avatar
Did a couple pulls the other day had been getting 11,8-12.1 at wot in 4rd so i lowered the boost!..at 22-23psi holding at 20
Today did some from 2-5th gear in My 3rd gear pull only held at 19psi but my innovate still said 11.9 4th gear held at 20-21 psi and so did 5th...
So my question is how can i get AFR to come down any further I guess because im already running unde stock boost st 3rd WOT
OR what could be causing my conflicting readings?
thanks
Old Jan 1, 2012 | 08:55 AM
5speedwtneed's Avatar
Boost leak?
Old Jan 1, 2012 | 12:55 PM
Blue_05EVO's Avatar
I checked and didn't find any, not to say its impossible for me to.miss one. But as of my last test I had zero, thanks though
Old Jan 1, 2012 | 01:02 PM
bigben's Avatar
What were the temperatures when you did each pull? Temp and barometric pressure might cause it to fluctuate. To put it in simpler terms, every time the weather changes, so does your boost and power output, if you're using a mbc anyway.
Old Jan 1, 2012 | 01:56 PM
Blue_05EVO's Avatar
40 degrees!!! Cold lol one other thing i have noticed is i put a cone filter on my car and vaccum went from 18-19 to 17-18
Old Jan 1, 2012 | 02:44 PM
3K's Avatar
3K
How old is your Wb? maybe you need to recalibrate the sensor.
Also if you didn't tune for the filter, might need a retune.
Old Jan 1, 2012 | 02:53 PM
Blue_05EVO's Avatar
Widebamd is 3 weeks old....lol...idles and cruises ar 14.2-14.3 sometimes up to 14.5-6
But I have inly calibrated it the free air way, and no I havnt re tuned for it yet....its just a filter not intake tube
Old Jan 1, 2012 | 03:39 PM
Raptord's Avatar
Lowering boost won't necessarily get you richer AFR's if you reach lower load cells which have leaner values in them. If you want a different AFR then adjust the fuel map, not boost.
Old Jan 1, 2012 | 05:00 PM
3K's Avatar
3K
But I have inly calibrated it the free air way, and no I havnt re tuned for it yet....its just a filter not intake tube.
Well the filter might not effect your idle, but its probably taking in more air under WOT. Also you won't get the same exact afrs all the time. Especially if you do back to back pulls, everything is heated up now the ecu will compensate by adding more fuel. Just look for consistency, 11.8, 11.9, 12.1 is pretty consistent. Just consistently lean though. Like Raptord said, Just add some fuel in those areas.
Old Jan 1, 2012 | 05:05 PM
Blue_05EVO's Avatar
Ok, ill have to find someone around here that can help me.out. thanks guys
Old Jan 1, 2012 | 07:34 PM
My03evo's Avatar
Exactly
berkel
May 18, 2012 09:03 PM
ithveno339jfkj4kjekjqqqq
Mar 1, 2012 06:25 AM
fabcas311
Nov 28, 2011 08:40 AM
EVO8LTW
Sep 7, 2010 03:44 PM
51
Apr 6, 2006 10:47 AM
