EvoVIII from norway
Old Apr 21, 2012 | 12:12 PM
powerstroke's Avatar
EvoVIII from norway
Hey guys
I've just purchased an evo viii -04 model. Odometer is 105000.
I was aware that it was a slight drivetrain noise before i was buying it. So I got it cheaper than normal.
It's most noticeable on 1st an 2nd gear, but I can hear it slightly in all gears.
Is it the tc? When the car is standing still, idling, and with clutch out, I also hear it. When I depress clutch the sound is gone.
And when i drive it fast for sharp corners I also get a rumbling noise from the front. Driving slowly on bumpy road i hear som clunking from the front end.
What can I expect guys?
I get a little bit of missfiring after shifting gears with full acceleration. Maybe it's the plugs.
The car has 3.5 turboback exhaust and open kn filter. No other mods.
Old Apr 23, 2012 | 06:55 AM
anyone?
Old Apr 23, 2012 | 07:14 AM
crazybaldhead's Avatar
Originally Posted by powerstroke
Hey guys
That's several problems.
The one that is gone when you depress the clutch is most likely the throw out bearing. It will need to be replaced, may be a good idea to change the clutch and pressure plate while you are at it.
The driving slowly on a bumpy road thing, I think is common to all evo's. There are a lot of theories, but I don't think anyone has narrowed it down exactly. Some say it is the strut mounts, the front sway bar, all kinds of things. Get it looked at in an alignment place to be sure.
Rumbling noise in front may be the tyres rubbing, or the wheel bearings, or even the tyres themselves making noise. What tyres are you using?What's the rim and tyre set up?
Misfire after shifting gears may be the wrong plug. I would put new ones to factory spec, if all you have is the air filter and turboback.
Goodluck!
Old Apr 25, 2012 | 10:05 AM
Ok, thanks. It's 'evo' tyres on the car. Haven't looked at them so carefully.
If I later have to replace the tc, can I use a tc from lancershop in the USA?
Or is it not the same like on my european vehicle? Someone who knows some place in europe to purchase a tc for a reasonable price?
The tc from lancershop in USA cost only 25% of what it costs here from the dealer in norway!
So if I understand correct, when I put on the new tc, I also get a new front diff?
Old Apr 25, 2012 | 10:51 AM
Murf's Avatar
If you need the transfer case just send it to shep trans. for a rebuild. The cases are shimmed wrong from the factory. And he will upgrade some of the things on the case that need it.
Old Apr 25, 2012 | 11:01 AM
OfaceGrimmins's Avatar
International shipping bro. He's from norway.
Old Apr 25, 2012 | 11:07 AM
Don't worry about the TC for now man. Fix the problems you have first. And the ones you do have don't sound too serious, just some maintenance.
Old Apr 26, 2012 | 10:59 AM
Are the wheel bearings the same for us models and european?
Can I buy them from usa on ebay?
Old Apr 26, 2012 | 12:04 PM
svt_lightning01's Avatar
If it is making the noise with clutch out but stops when you press it to the floor it's more likely the input shaft bearing as the tob would do the opposite.
Old Apr 27, 2012 | 10:22 AM
Ramatzio's Avatar
Yes, but use OEM not ebay. Still just 1/3 of the price after shipping and tax compared to buying them her..
http://www.streettunedmotorsports.co...drivetrain.htm
Old Apr 27, 2012 | 11:28 PM
dntdrvslow's Avatar
unless the transfer case is really loud i would just change all fluids and rock that car out! fix the front end noises as you can those are straight forward maintanence. its not a quiet car you will know when some thing is really wrong
EEVOH
17
May 31, 2015 08:44 AM
AlexGutEvo8
May 24, 2015 11:35 PM
OG
12
Apr 19, 2013 05:39 PM
svt_lightning01
Aug 10, 2011 10:07 PM
SLO-EVO
Nov 9, 2010 11:59 AM
