0 Vacuum at idle HELP!
Old Nov 4, 2012 | 04:04 PM
  #121
Spec-Ops1's Avatar
Dang that is crazy...
Old Nov 4, 2012 | 05:01 PM
  #122
Steven's Avatar
Originally Posted by 5LEEPERISAH23I
yea, Tom was worried about it moving when we were putting together the motor. I really thought that would never happen and it did. Pretty crazy it didnt hit piston to valve, guess i lucked out on that. Everyone says, "sounds like timing problem." well it was just not visible till you pull the motor.
and PS Tom. That ruler is showing more then a 1/2 inch.. that is pretty much 3/4 of a inch! lol
I believe the belt timing was still correct, so you wouldn't have to worry about pistons hitting valves. If it was just the trigger plate, your ignition timing would have been the issue. That could have caused catastrophic engine failure at WOT. Either way, it seems that you got lucky!
Old Nov 4, 2012 | 05:44 PM
  #123
tscompusa's Avatar
we ordered a new crank key (woodruff key), new trigger plate, and a fluidampr crank pulley + new cometic hg etc. ill post a video once i fire the car back up & perform leakdown test to confirm everything is back to normal.
hopefully this thread will help someone else diagnose this issue if it ever happens to anyone in the future.
Old Nov 4, 2012 | 09:11 PM
  #124
5LEEPERISAH23I's Avatar
Lets hope this is for sure the problem. We might be shooting the gun, but this is def. a issues regardless if it was the problem or not.
Old Nov 4, 2012 | 09:39 PM
  #125
tscompusa's Avatar
its definitely fixed don't worry.
Old Nov 5, 2012 | 03:42 AM
  #126
evilempire76's Avatar
Glad you found the issue.
Old Nov 5, 2012 | 12:00 PM
  #127
we have everything order. I would hope will be running by the weekend
Old Nov 5, 2012 | 10:17 PM
  #128
prowakeskater's Avatar
wow. this is quite the success story.
Old Nov 5, 2012 | 10:56 PM
  #129
Lyzek01's Avatar
So the engine timing was off throughout the whole time? Or did it jump timing when going down the track? I thought a compression test was done after the issue started? That would show low compression! I feel for the Guy who has replaced so many things if this was the issue since day 1! I hope this fixes the issues and notes are taken to prevent same issues.
Old Nov 6, 2012 | 05:02 AM
  #130
badev0's Avatar
Wow that is crazy. Glad it wasn't anything too major.
Old Nov 6, 2012 | 06:23 AM
  #131
Levar's Avatar
Veteran: Army
Wow! This was some serious troubleshooting.
Old Nov 6, 2012 | 06:27 AM
  #132
Lyzek01's Avatar
So I reread the diagnosis, and you mentioned the Timing belt was correct but the CAS plate was off. Wasn't this noticed when changing the sensor?
Old Nov 6, 2012 | 09:44 AM
  #133
It was not noticed. Something you really would no be looking for when changing a crank angle sensor. Vision is limited to in there. When it says its in timed why look for something proving it isnt in timed.
Old Nov 6, 2012 | 09:45 AM
  #134
all parts will be in TOMORROW! car should be running by the end of the weekend.
Old Nov 6, 2012 | 02:48 PM
  #135
Lyzek01's Avatar
Dude. I really hope to see you get your car back soon. If its fixed you should be able to put better #'s down. due to the Coil Packs and should have a better time at the track. 10s maybe.
