Is this wing salvagable??
Old Oct 9, 2012 | 03:35 PM
  #31
sourtowel's Avatar
Is this the right stuff? As far as brands are concerned, which is better or is it all the same. Also does the type of sprayer matter? (top-feed, Bottom-feed) Im looking forward to getting this finished so I can post the result of hours of hand-sanding.
http://www.ebay.com/itm/Automotive-C...a7ecbc&vxp=mtr
Old Oct 10, 2012 | 03:20 AM
  #32
hatesposers's Avatar
Just by your questions, i would say youre going down the wrong path
While everyone has a "first" project, you dont want to be using a $1000 wing to be learning gun settings, how to mix catalyst, reducers, and proper spray technique.
Buy yourself a $20 rattle can of spray max 2k clear and follow the directions.
http://www.spraymax.com/index.php?id=361&L=1
Then after you have the pride of accomplishing something well, learn the frustration of "effing" up a paint job on a cheap $20 fender from the junk yard.
Now for your questions:
No. All clears are not all the same. There are cheap clears and there are good clears. Good clears are high solids, have uv inhibitors and are truly clear (not yellow). Brands to look for are dupont, PPG, SEM (and i will be playing with some ALSA soon). Custom painters have good and bad to say about House of Kolor.
I would stay away from purchasing paints from Ebay as you may get the cheap old paint that has been sitting on a shelf for years
As for guns. I use gravity fed HVLP guns. A cheap gun will spray as good as an expensive gun for the first job. An expensive gun will spray as good as its first day for a long long time. Just make sure to spend alot of time cleaning it after each use. Gun brands are like condom brands. Everyone has their favorites and are typically loyal
Old Oct 10, 2012 | 03:37 AM
  #33
jt3's Avatar
jt3
I think it is salvageable from the pics. There are a few tutorials on the forum on how to do this (if you need the steps).
For carbon wrapping it, even if you apply clear coats, you can still tell it's not the real thing haha.
Old Oct 10, 2012 | 04:16 PM
  #34
SRT4toEVO's Avatar
It can deff be done, mine looked just as bad and now looks almost brand new. The only spots you can notice is where the carbon fiber was completely dried out and cracking. Now there are tiny spots where it "bleeds" and appears darker than the rest. But good thing that was on the bottom side.
BEFORE: this is also after it has been recleared before by the previous owner a couple of times.
AFTER:
Old Oct 10, 2012 | 04:31 PM
  #35
SaulHudson's Avatar
Very good info here, one thing to note :
I know nobody likes to, but READ THE DIRECTIONS!!!!!!!!!!!! IT will tell you how to mix the stuff, will give you a ratio.
Old Oct 10, 2012 | 06:21 PM
  #36
sourtowel's Avatar
Thanks man. good info. I read the "how to" before I started this project by the way. That is why I opted to wetsand it instead of other options. It should be ready for clear by Friday.
Old Oct 10, 2012 | 06:28 PM
  #37
SyZyGy1394's Avatar
AND you don't get a full carbon fiber VIII wing, you get a IX wing with carbon fiber spoiler and fiberglass sides
Plastic. The sides are plastic.
Old Oct 10, 2012 | 06:34 PM
  #38
binky's Avatar
FWIW, this thread might help you out:
https://www.evolutionm.net/forums/ev...bon-wings.html
-Bink
Old Oct 10, 2012 | 07:51 PM
  #39
RoMeIX's Avatar
Sand it down and paint it flat black!
Old Oct 11, 2012 | 07:07 PM
  #40
jeremy52048's Avatar
i just re did mine . was about 4 hours of just sanding, but even if it doesnt come out perfect it will be MUCH
Old Oct 12, 2012 | 05:31 PM
  #41
Evobro19's Avatar
Salvageable ..mine was the same and now it's like new..takes time n effort oh and allot of patience haha
Old Oct 19, 2012 | 01:16 AM
  #42
FROMWRX2EVO8's Avatar
I have seen plenty worse.
Hell, mine was horrid.
apexbeast
May 13, 2014 09:01 AM
apexbeast
May 12, 2014 11:06 AM
KamG562
Nov 25, 2013 08:50 AM
AWC
AWD Lancer (2012 +)
Sep 4, 2013 08:14 AM
