help
Old Mar 3, 2013 | 12:29 PM
rbmxer's Avatar
help
Ive ran into an issue, can't figure out what the problem is...Anyways after I installed powerxs intercooler, greddy rs bov (recirc), uicp, injenintake, and a 3" dp the car would have a slight rough idle on cold but would get better within few seconds...Heres where the the issue is, when I drive it, it doesn't go past 1.5-2k revs and starts to bog, but when it idles it revs fineup to the rev limiter so need suggestions...thanks
Old Mar 3, 2013 | 12:32 PM
fastyouth1313's Avatar
It ran fine before?
Old Mar 3, 2013 | 12:36 PM
Hendrixmx's Avatar
Did you do a boost leak test after installing everything?
Old Mar 3, 2013 | 12:56 PM
rbmxer's Avatar
It ran perfect on the OEM parts, and no I didn't check for boost leaks...but even with boost leak it should still drive, pick up revs, no?
Old Mar 3, 2013 | 01:08 PM
joshua_s's Avatar
If you have a decent size leak in the system somewhere that could be whats causing your issue. Its always good to boost leak test the system regularly.
Old Mar 3, 2013 | 01:36 PM
Moready's Avatar
Boost Leak Test
Old Mar 3, 2013 | 02:06 PM
rbmxer's Avatar
I figured it was just a boost leak hopefully...but alight, ill check it out, ill update
Old Mar 3, 2013 | 02:14 PM
SABSquid's Avatar
+1 on the boost leak test!
Good luck.
t0rxe
Lancer Engine Tech
Mar 23, 2016 10:11 AM
wwcagedevo8
11
Aug 4, 2014 06:03 PM
ninemr
22
May 23, 2014 12:52 AM
schow001
Mar 28, 2014 06:20 AM
MrJuls
Jan 18, 2014 03:26 PM
