starting problems
Old Apr 28, 2013 | 07:01 AM
addicted2speed's Avatar
Starting problems??????????
Hey All Having Starting Problems... For A Year And A half now. When I turn The Key It Goes ClIck Third starter. Sometimes It Starts About 50% Of The clicking Happens. My Alternator Still Charges, My Battery Isnt Dead But Im Guessing Its not Holding A Charge As Good As It Use To But Its only About 7Months Old And Im In Az. Have Hks 272 Cams And An Exedy Twin Plate Clutch With A New Fly Wheel...Would These Parts Cause Starting ToBe a Little Tough?? Im Thinking It Would Be But Not That Much. Please Someone Give Me Some Info.
Other Upgrades;
wingz performance tune
Walborro 255
1450 Injectors
Fp White Turbo
Full Exhaust
Ets Intercooler W/ 2 1/2" Piping
Sd Tune
E85
440Hp 410Tq @28psi
Old May 10, 2013 | 01:57 PM
donzilla2004's Avatar
I battled a hard start issue for awhile too, ended up that I had a dead cell in my battery, I replaced my battery which was only 2 months old at the time and fixed the issue, it hasn't happened since then. I would start with your battery personally.
Old May 10, 2013 | 02:10 PM
Ev0ikon's Avatar
To prove defective battery is easy if you have another known-good-and-hot battery.
Old May 11, 2013 | 09:06 AM
new BatterY And New Starter Only 3 weeks Old I'mThinking NowThe IgnitionSwitch
Old May 11, 2013 | 10:39 PM
Are you getting a no crank, no start condition. Or crank, no start condition?
Old May 12, 2013 | 07:24 AM
It Doesnt Even Crank. The Starter Just Makes A Click Sound. But Im Positive Now Its The Ignition Switch. When It Doesnt Start I Turn The Key back To the Off Position And Then Turn It, It's Been Turning On Every Time Now..
Old May 12, 2013 | 07:31 AM
rmorr79's Avatar
might sound stupid but any chance the battery terminals are bad?
Old May 12, 2013 | 07:41 AM
Boost_Inspired's Avatar
there is a thread on this , take the plastic covers off right behind the steering wheel. Should just be 3 phillips screws from underneath and on the left hand side there is a switch that is white and only held on by one phillips screw. If you can move that at all i needs to be tightened and you will probably only be able to get an offset screwdriver on it. Tighten that up and see if the intermittent no start goes away.
Old May 12, 2013 | 07:43 AM
https://www.evolutionm.net/forums/ev...ied-fixed.html
here is the thread
Old May 12, 2013 | 08:34 PM
hatesposers's Avatar
There are other causes of this same problem as well. See My thread on the issue. It was not my switch.
Old May 13, 2013 | 11:31 PM
EvolutionRR's Avatar
I would replace batter, starter, and alternator ..than no more problems
Old May 14, 2013 | 05:32 PM
Robdeep3's Avatar
Better to find the actual reason for why it's not starting then buying expensive parts you don't need trying to fix it blindly.
Old May 14, 2013 | 05:41 PM
MR05's Avatar
+1
hhenryjin
Lancer Troubleshooting
Jul 17, 2014 08:52 PM
live2teach
Jul 15, 2014 05:22 PM
addicted2speed
Jun 21, 2013 09:44 AM
addicted2speed
May 11, 2013 11:55 AM
xisien
50
Jul 1, 2009 07:12 AM
