Brake & battery lights on
Old Jul 4, 2013 | 11:21 AM
Luke18's Avatar
Hello,
Both my brake and battery light came on at the same time when I was driving. I know that it usually indicated a bad alternator because it happen a month ago so I replaced it. Just for the hell of it I pulled the positive terminal off and the car stayed running so the alternator is working fine. Could anyone advices me what else to check?
Old Jul 4, 2013 | 11:40 AM
Paul Walkin's Avatar
Alternator could be working fine but charging out of range (high or low) which will trigger the lights.
Old Jul 4, 2013 | 11:46 AM
Luke18's Avatar
How would I check if that is the issue? And if that is the case how do I fix it?
Old Jul 4, 2013 | 12:17 PM
AJsGenerX's Avatar
A Volt meter will give you a reading. I'm not sure what specs are but I'm sure the interwebz has them somewhere.
Old Jul 4, 2013 | 09:34 PM
SmurfZilla's Avatar
if you have access to a tactrix cable see if the battery is getting 13-14v's when the car is running (or use a volt meter). If it isn't check the plug going to the alternator (the 4 pin one). Make sure its on securely. if it feels like it is tug on it a little and see if it moves easily.
BRalliart
Aug 22, 2015 08:01 AM
waid302
Apr 7, 2015 08:13 AM
TreatsIX
Oct 25, 2013 02:50 PM
Evilution23
10
Jun 1, 2013 01:03 AM
