help! car rattles at 2000rpm!
Old Aug 3, 2013 | 12:39 AM
gkew's Avatar
RE EDITT!!!
the rattle is right next to my right foot where the gas pedal is! its like a spinning fluttering sound
so recently I've been having this rattle and it feels like its coming from dead center right under the stick shift just directly below the cd player. It does not rattle while at idle. it rattles exactly at 2000 RPM, wether I gas to get to 2000rpm or coasting, or gasing up at or to 2000rpm and also rattles in between shifts.. It doesn't matter which gear im in, as long as the RPM hits 2000, it rattles.. it stops rattling once I pass 2000 rpm. It seems and feels as tho its the tranny thats doing the rattling.
Old Aug 3, 2013 | 02:46 AM
bdonIX's Avatar
check your exhaust. Make sure all bolts are tight and there are no leaks. make sure your downpipe is properly fit and not slapping anything (if you have aftermarket).
my old exhaust had a resonator in it and a piece of metal in it got loose and would rattle at 2-3k rpm...it drove me crazy haha.
Old Aug 3, 2013 | 04:25 AM
b00stah0lic's Avatar
Probably is exhaust related, especially if you have an aftermarket downpipe with no flex section.
Old Aug 3, 2013 | 10:55 AM
gkew's Avatar
Actually its not the 'car' more like the a fluttering spinnin sound rattlingish feels like it coming from the tranns
Old Aug 3, 2013 | 10:59 AM
itsmrrizz2you's Avatar
maybe something on the driveshaft or something??? i would say exhaust most likely
Old Aug 3, 2013 | 11:54 AM
allevolution's Avatar
well you forgot to list mileage of the car but-
sounds like a carrier bearing or a loose exhaust shield maybe
PS, the tranny is not under the car or even near being under the car..
Old Aug 3, 2013 | 08:18 PM
gkew's Avatar
it feel as if the fluttering or that spinning sound is right under the radio
Old Aug 3, 2013 | 09:00 PM
SilverShadow03's Avatar
Have a friend rev the motorto 2000 rpm while you stick your head under the car and in the engine bay and report back...hell jack up one side and with a jackstand and leave the jack for safety then slide under there and look, listen and feel for your rattle.
Old Aug 3, 2013 | 10:29 PM
there is an exhaust shield that runs pretty much the length of the driveshaft.
I would say its that.
only way youre going to solve this is looking for yourself. Its literally the easiest thing you can do
Old Aug 3, 2013 | 10:47 PM
llDemonll's Avatar
Check the down pipe is clearing the cross brace as well
Old Aug 3, 2013 | 11:19 PM
gkew's Avatar
Downpipe is perfectly fine. Car only rattles when gear is engaged so i doubt ill be able to be under and figure out the rattle
eddy5201314
Jan 8, 2017 10:12 PM
Steak42
Jun 23, 2015 01:56 PM
Crester
Evo X How Tos / Installations
Sep 30, 2011 06:59 AM
stackhouse
Jul 7, 2011 06:41 PM
efecitiy231
Lancer Troubleshooting
Jun 8, 2011 11:20 AM
