Some help please!?!?!?
Old Sep 16, 2013 | 03:53 AM
her name is eva's Avatar
I just got the 03. The mods is ets ip kit, cams (unknown/supposedly), fuel pump, forge bov, stock turbo, 3 inch dp full exhaust, and tune. I've done my research and just about the only testing I have not done is on the coil packs and compression test. I saw the post about upgrades and thinking about getting coil on packs. Any suggestions?
My problems is under wot, it will start to like miss fire or something every now and then. It had ngk brk7es I was told it was tuned on brk7eix. So I put them in. Helped out a little. My vacuum is around 6 to 7 at idle I turned the boost down to 18 and still does it. My afr under wot is 10.7-11.3 when it doess the little jumping back situation, every now and then it will hit like 12.1 but not all the time.
My mods to do coil on plug, port turbo mani, upgrade turbo, and tune. I dont want to start on that until I get all the bugs out. I fixed both boost leaks and now I do not know what to do. I know its hard to say, when the car is not in front of you also is the problem quite common on these cars? Only asked cause I've seen alot of post about it.
Old Sep 16, 2013 | 04:29 AM
nelale2's Avatar
make sure your plugs are gapped correctly. WOT missfire sounds like spark blow out
Old Sep 16, 2013 | 05:04 AM
They are at .26
May not be misfire. Idk could be its just getting to the point where I'm about ready to drop it off and pay some one.
Old Sep 16, 2013 | 05:14 AM
chu's Avatar
chu
BRK7ES does not sound like the right plugs...
I have an 8 also and have ran BR7ES or BPR7ES for copper plugs. For Iridium, I have only ran OEM. Never ever had an issue with spark.
http://www.extremepsi.com/store/home.php?cat=567
Old Sep 16, 2013 | 05:22 AM
J_Striker's Avatar
To only have 6 or 7 in/HG at idle is low unless they are are giant cams. Check timing first. If that checks good, do a compression test. If that fails, do a leakdown test.
Old Sep 16, 2013 | 06:01 AM
Sorry they were the copper so I went to iridium. Ok I will try to check the other things when I get time. I hope it is nothing internally. It just started like not to long after I bought the car. Hasn't always done it.
Old Sep 16, 2013 | 08:19 AM
cwyteboi's Avatar
So is the BOV recirculated or VTA? If it's VTA you might get that missing or stuttering sound and feeling at higher RPM. My friends VIII does that, but he likes the sound of VTA so he lives with it. If in fact this what is going on.
Old Sep 16, 2013 | 09:33 AM
It is recirculated
Old Sep 16, 2013 | 09:40 AM
Also does anyone else have this problem? Every now and then when you first start it up. Its almost like it is skipping until it warms up a bit.
Old Sep 16, 2013 | 09:41 AM
sujinX's Avatar
have u checked for boost leaks again and at what pressure? because thats a very low vacuum.
can u verify those spark plugs? that "k" seems rather odd. iridium is IX.
is it really tuned?
Old Sep 16, 2013 | 02:03 PM
nelale2's Avatar
are you talking at low speeds (0-10mph)?
if so, I think this is a turbo thing. My s13 would do this when it was cold/cold weather and hadn't warmed up yet.
Old Sep 17, 2013 | 06:05 AM
Its suppose to be tuned. At full throttle 25 psi afr is 10.7-11.3 factory turbo. And ill have to check the part number on the plugs again. I havent had a chance to do another boost leak test but last time I checked it. We did around 30 psi.
Old Sep 17, 2013 | 06:13 AM
BPR7EIX NGK is the ones I just put in there
Old Oct 2, 2013 | 04:45 AM
Just want to say I finally got it right. I bought everything to do a coil on plug set up, regapped spark plugs, and alot of other stuff. Only to find out gapping plugs with that coin gapper was a stupid idea. Spent the money on a better gapper. Couldn't be more happier.lol
bertVIII
19
Nov 13, 2018 06:41 PM
badreligi0n
15
Sep 15, 2016 07:57 AM
edo
Aug 31, 2011 04:56 AM
Noize
29
May 20, 2005 12:00 AM
ozracer4
Lancer Aftermarket Forced Induction Tech
Jul 26, 2004 05:16 PM
