smog time
Old Apr 4, 2014 | 01:29 PM
nanievolution's Avatar
smog time
I just received my first smog check test requirement' . I'm looking for a smog shop in fountain valley or surrounding (south oc) areas where I can take my evo and not get rejected. I'm sure I'll be fine to pass don't have much in the car for this reason '. I only have injen I/c/p turboxs intercooler that's it . any suggestions?
Old Apr 4, 2014 | 03:12 PM
Bhsj13's Avatar
You will be fine. Take it to any shop.
Old Apr 4, 2014 | 03:22 PM
slowsrt4:('s Avatar
they didn't care when I was in cali as long as I passed the test where they actually put it on the dyno, which pretty much just required the cat to be installed
Old Apr 4, 2014 | 11:05 PM
TommiM's Avatar
They don't put awd cars on the dyno. they do an idle and, I believe, a 2500 rpm test.
Your lucky either way, I was given crap about my intercooler pipes, I guess it didn't help that my cams were loping really bad. I went untuned and actually passed by the skin of my teeth, max HC was 100 ppm, I was at 94ppm. Long story short, the reason was I NEEDED to be smogged asap otherwise its silly to try and get smogged with an untuned car. I did and passed, yay.
Old Apr 4, 2014 | 11:26 PM
G20's Avatar
G20
Euclid/Trask right before 22 entrance in a gas station. Run your car hard for about 15 to 20 minutes (take the freeway long way there). Are you the GG evo in the Ward/Warner area? Injen intake without proper tuned may give some trouble.
Old Apr 7, 2014 | 04:50 PM
Thanks, I'm located by euclid and edinger
Old Apr 7, 2014 | 04:51 PM
Thanks for the input guys!!!!!!
MR.ev021
23
Dec 4, 2016 04:54 AM
eeeeevo
18
Nov 2, 2016 02:32 PM
benIX
May 6, 2016 02:00 PM
Khm525
Oct 27, 2015 10:53 PM
NorCal Lancer
10
Jan 23, 2012 11:59 PM
