Grinding sound when turning right under power only
Old Mar 5, 2015 | 05:01 PM
AKW89's Avatar
Okay, so I have a 2005 with ACD. The car just developed this issue over night. When I turn right, and right only, the car makes a really low grinding type noise. The car also gets a slight vibration I can kind of feel. If I turn right while coasting (in or out of gear) there is no noise. However, when giving it power, the sound happens. I am thinking the worst right now but hopefully someone will at least have went through this before so I can get any answer.
Old Mar 6, 2015 | 03:45 AM
egis's Avatar
Start with simple stuff.jack up the car and start moving wheels could be wheel bearing,check cv couplers if they in tact stuff like that. Could be axle. Good luck.
Old Mar 6, 2015 | 03:55 AM
AKW89's Avatar
Thanks man will do.
Old Mar 6, 2015 | 09:13 AM
GTijoejoe's Avatar
Sounds like the outboard joint of an axle is bad.
Second to that could be a bearing, but normally is an axle issue.
Hope that helps
Old Mar 6, 2015 | 11:14 AM
Malfury's Avatar
I had a similar issue when I got my car fixed from running over a valve in the middle of the road. I noticed when I turned right, I would hear a nasty grinding sound. I checked under, and it turned out, my wheels were scraping against the new splash guard they put in.. so I cut a piece out and no more noise. Might be an idea for you.
Old Mar 6, 2015 | 07:29 PM
AKW89's Avatar
Hope that helps
Thank you, I hope that's what is wrong. I definitely prefer an axle to expensive stuff.
Thanks to all of you. Always a great help when I post on the evo m boards.
Old Apr 7, 2015 | 08:32 PM
ali911's Avatar
Any update on this?
Old Apr 19, 2015 | 06:56 PM
MRadjahoe's Avatar
check your CV boots especially on the passenger
Old Apr 20, 2015 | 06:24 PM
spitefire1's Avatar
noise
sound like deff a cv joint issue.. does it do it at all speeds?
ninthtale
Lancer Troubleshooting
Aug 10, 2015 06:59 PM
mx4life85
May 30, 2010 09:02 PM
screwnutbolt
Feb 2, 2010 08:26 AM
pjb00stin
Oct 10, 2008 08:33 AM
