Evo smoking after cam and turbo install
Old May 4, 2015 | 06:12 PM
manthny18's Avatar
Hey guys. I Have a evo 9. My car started smoking after I installed cosworth m2 cams(camsonly) and a t3 set up. Ams manifold pte 6266 jb. Trying to figure if the turbo is shot or if its the valve seals. I got the turbo kit off a good friend he bought it brand new only using it for around 100 miles before is clutch went and car sat for about 9 months before he decided to put the car to stock and sell it my car sometimes smokes without accelerating it but smokes a lot after accel. lmk guys thanks for you help. Here's a video.
Old May 5, 2015 | 06:46 AM
manthny18's Avatar
Bump
Old May 5, 2015 | 07:02 AM
Ev0ikon's Avatar
I can't tell from the vid - what color is the smoke?
Old May 5, 2015 | 08:33 PM
manthny18's Avatar
I took the turbo off today lots of oil in the hot side. Turbo is busted. I ran i -4an oil feed with no restrictor. From the research i did I need to run a -3an line or a -4an with restrictor. Anyone can confirm this. But i need to send the turbo for a rebuild first.
Old May 5, 2015 | 11:46 PM
Evo9_Dubai's Avatar
afaik oil restrictor is required on the BB, not JB, but I am not sure about the -3an/-4an.
Just like you said, send it back for a rebuild and ask precision to upgrade it to a BB unit.
Old May 6, 2015 | 08:18 AM
Ev0ikon's Avatar
Smoke Color looks white on my computer at home so I suggest you clean out the PCV valve and try again.
Old May 7, 2015 | 03:50 PM
manthny18's Avatar
Thanks guys i sent the turbo out for a rebuild
Old May 7, 2015 | 06:28 PM
essej's Avatar
Wow that's unfortunate I hope the restrictor was the problem, ballbearing turbos require lots of different factors in order to run them. Make sure you run the correct oil too
Old May 7, 2015 | 07:03 PM
evo8rob's Avatar
Did you run it off of the head or the oil filter housing also?
Old May 8, 2015 | 08:04 AM
manthny18's Avatar
It was run from the oil filter housing.
Old May 8, 2015 | 11:26 AM
manthny18's Avatar
Installed the stock turbo till my other gets in. Guess what no smoke.
Grimgrak
Jan 15, 2013 05:46 PM
Frew
Mar 5, 2012 07:06 PM
evo8matt
Aug 7, 2011 07:37 PM
imapunkclaimer
Apr 15, 2004 01:50 PM
