Newly built 2.0 liter 4g63
Old Nov 19, 2015 | 05:47 PM
Sheasta's Avatar
I change every 3k, I run E85 pretty much full time. Built motors that are built right do not use any more oil than a stock one. That being your engine also uses very little oil, nothing to be worried about there.
Which oil are you using ?
Old Nov 19, 2015 | 10:34 PM
LetsGetThisDone's Avatar
I was using Amsoil Zrod 10w30. I switched to Amsoil signature series 5w50 since I'm now making a lot more power than a stock turbo and my tuner said o start using a 50 weight oil. And the ball bearing turbo doesn't need the ZDDP like your journal bearing turbo. I like to 5w50 over a 20w50 because it's still decently thin for cold starts on cold mornings or night.
Old Nov 20, 2015 | 01:09 PM
Sheasta's Avatar
So with this thicker oil should I be letting the car get up to operating temperature fully in the morning before driving it ? It gets really cold here In Chicagoland. I'm considering changing to a 5w 50 instead...
Old Nov 20, 2015 | 01:28 PM
Klaiceps's Avatar
Originally Posted by Sheasta
The amsoil zrod is fully synthetic and it says for modified engines it can go to 3,000 miles between service intervals ... I think I'll give this a try.
Turndown , how often are you changing your oil ? We seem to be using the same stuff currently.
Still open to more opinions.
Thanks guys
I'm using Amsoil Z-Rod 10W-30 and according to my oil analysis I can go more than 3,000 miles on it. My car has an FP Green turbo with cams on a stock block and head.
https://www.evolutionm.net/forums/ev...l#post11536014
Old Nov 20, 2015 | 01:45 PM
I let my coolant temp get to about 100* before I start driving, it only takes a minute or two. And then I take it easy for a good 10-15 minutes before I lean on it. Letting it idle to warm up all the way is just wasting fuel.
Old Nov 20, 2015 | 03:47 PM
Sheasta's Avatar
I'm going to look at the pricing for the amsoil z rod. Is it possible to get 4,000 miles since its full synthetic or is that frowned upon?
Old Nov 20, 2015 | 03:55 PM
Turndown's Avatar
Veteran: Army
Don't do that unless you want to waste fuel and engine life... Give it a minute or two to get oil in the head and get the coolant warm then drive it. I don't rip on it until oil is up to operating temp but that is up to you if you want to with your car
David Buschur
59
May 14, 2012 02:52 PM
Fast Frank
12
Nov 28, 2009 12:25 PM
allmotorking
Dec 5, 2008 02:37 PM
scottsee
Mar 27, 2005 07:42 AM
liquidlancer
21
Feb 13, 2005 08:28 AM
