Transmission problem?? Pls help
Old Nov 6, 2016 | 08:02 AM
Ferp's Avatar
Originally Posted by eddy5201314
yeah I have exedy stage 2 in mind at the moment, is it a good ideal to change lighter flywheel too?
I have a lightweight flywheel. Eithers good though.
Old Nov 6, 2016 | 09:49 PM
eddy5201314's Avatar
Okay thanks,
does anyone know what's the best transmission fluid for evo 9 6 speed? I want to replace transfer case and rear diff fluid at the same time as well, is the OEM Mitsubishi fluid good?
Old Nov 9, 2016 | 10:50 AM
astral's Avatar
Replace your fluids with all OEM, throughout the trans, diffs, as was stated already in this thread.
Use a synchro mesh fluid additive in your transmission. e
I'll go ahead and spoon feed it to you.
https://www.amazon.com/ACDelco-10-40...gm+synchromesh
Old Nov 9, 2016 | 03:34 PM
thanks a lot, is that additive just add straight on mix with the transmission fluid?
Old Dec 7, 2016 | 04:13 PM
evoyang87's Avatar
Sorry if I am using this thread to post my issues too, but I did not feel the need to start another thread for a possible related issue. I apologize in advance for the long post.
I drive a 2005 Evolution MR and just recently had a brand new clutch installed. When I got my clutch installed, the mechanic informed me that he was not able to bolt down the subframe properly because one of the bolts was rusted. He told me that I may or may not hear a rattle while driving, but if I do then I should not be overly concerned because it should not affect drivability and that I can bring it back to get it taken care of. I drove the vehicle back home and did not notice any noise. The next day I began hearing a rattling sound when the vehicle is in gear and when I am accelerating and maintaining speed, but whenever the vehicle is in neutral the rattling stops. The rattling comes and goes, but always when the vehicle is in gear and in motion. I took the vehicle back and the mechanic took it for a test drive and confirmed there was a rattle. He was able to bolt the subframe properly and informed that the rattle should no longer be there.
While halfway to my house from the shop, the rattling sound started again. I am confused as to what is causing it. Researching the forums, a lot of people are stating that their vehicle makes a rattling noise only when it is in neutral and it is caused by a throw out bearing. The rattle goes away when the clutch is engaged and the vehicle is in motion. I have found that my vehicle is the opposite. Description of the rattle sounds like two metal rods vibrating against each other. I can feel the vibration on the gas pedal when I accelerate and when I maintain speed. It tends to get worse if the road is bumpy and at high speeds. Only thing I have not tried is WOT because I do not know where the rattle is coming from or what the cause of it might be in fear that something might break if I do. Has anyone experienced this and could this be the throw out bearing going bad? The rattle is really starting to make me worried. Thanks!!
Old Dec 8, 2016 | 09:11 AM
evoyang87's Avatar
Bump for help??
Old Dec 8, 2016 | 09:19 AM
Originally Posted by evoyang87
Bump for help??
This maybe your issue here. See link
https://www.evolutionm.net/forums/ev...g-how-fix.html
eddy5201314
Nov 4, 2016 02:14 PM
CrackerJackToy
Sep 4, 2007 02:05 PM
EVILutionVIII
Aug 12, 2007 11:38 AM
evo racing
Jun 3, 2006 08:36 PM
evo8silver
Feb 6, 2005 06:01 PM
