Coolant leak? Green fluid on top of tcase
Old Dec 10, 2016 | 10:20 AM
barneyb's Avatar
Lets say for some reason you think there's air in the cooling system but you are wrong. In this situation, when the coolant climbs up the funnel and the thermostat opens, the coolant in the funnel just stays there. With an actual coolant funnel you insert the plug and dump the expanded excess into the reservoir. With a regular funnel you got a mess.
Normally we wouldn't be going through this process unless we've drained the cooling system and know that there is air in the system. About the only time our cars overheat is when there is a head gasket problem and then there constantly is air in the system.
Old Apr 17, 2017 | 01:05 AM
RightSaid fred's Avatar
Leaking head gasket.
If your headgasket is sealed like it's supposed to be, you don't need a funnel.
Old Apr 19, 2017 | 09:23 AM
LetsGetThisDone's Avatar
Originally Posted by Fast_Freddie
It is 3/8" hose... I just ordered some 3/8" silicone coolant hose... vibrant sells some
Originally Posted by Bmurray
Thanks. Will i need to bleed the cooling system?
Get OEM hoses and clamps. They're not that expensive and they'll last another 10 years. I chased coolant leaks forever, after initially replacing the turbo water lines with 3/8 hose and worm drive clamps. Finally went back to OEM hose and clamps there after going through just about everything, and no more leaks..
Old Apr 19, 2017 | 10:08 AM
Bmurray's Avatar
Thanks.i fixed this a while back. The guy above you bumped it for some reason. It was the coolant hose going to my turbo had a little split in it.
Old Apr 19, 2017 | 10:39 AM
Well, if you used aftermarket hose and clamps, look there first if any leaks come back in that area...lol
Old Apr 19, 2017 | 01:39 PM
Hoses pop for no other reason than too much pressure.
That's just a symptom of another cause which causes other symptoms as well.
If you can figure that out?
You might think it's fixed but you're still making threads for "my car is still broken".
Old Apr 19, 2017 | 04:51 PM
No, these cars are aging. An 8-12 year old rubber hose splitting is going to happen..
EvilDSM97
Jul 16, 2016 06:10 PM
fireroasted
Mar 22, 2013 04:28 PM
randomevo
11
Mar 14, 2013 02:37 PM
EvoPowered9
Apr 13, 2012 02:03 PM
EvoTeyn
Aug 27, 2011 09:23 PM
