New Guy
Old Dec 18, 2016 | 08:27 PM
Rome97's Avatar
Veteran: Navy
New Guy
I own an 2003 Evolution Gsr and im broke any tips and tricks i should know
Old Dec 18, 2016 | 09:35 PM
LetsGetThisDone's Avatar
If you're broke, leave it alone.
Old Dec 18, 2016 | 09:41 PM
Biggiesacks's Avatar
launch sparingly lol. Wheel hop is the death of the spider gears of the stock front open diff. Tires and brakes are 2 things you should never skimp on. Start a maintenance fund and make sure you do all the scheduled maintenance, otherwise it will cost you much much more if you don't.
Old Dec 18, 2016 | 10:38 PM
Rome97's Avatar
Veteran: Navy
thanks you all for the advice
Old Dec 18, 2016 | 10:40 PM
Rome97's Avatar
Veteran: Navy
your talking about t-case
the front diff is tcase right?
Old Dec 19, 2016 | 06:07 AM
^^^You are correct!
I see you joined in May & are now posting up Glad to have you join us here on EVOM
Let us know if you have further questions
Heres what it looks like FYI (item 6) (EVO 9 version w/ACD)
Old Dec 19, 2016 | 08:35 AM
Klaiceps's Avatar
I second this. Just be sure to keep up with maintenance and you'll be fine.
Old Dec 19, 2016 | 11:13 AM
The front differential is inside the tcase. If you launch car wrong, it can cause quite a bit of damage if it explodes. If you're lucky it'll just break and not take out anything else. There is also the factor that a bad launch can hurt the ring and pinion gears of the tcase.
Yup. If you're truly broke, it is not a good idea to do anything more than maintenance items. Piecing together $200-$500 at a time to do mods and get it tuned is cool, until all of this causes premature failure of a larger component you can't afford, leaving the car parked for 3 months. Like a clutch that was already kind of on it last leg, then turning up the power makes it slip, and you just blew your wad on parts/tune. So now the car sits because you don't have $1800 to replace the clutch..
Broxma
Jan 30, 2008 08:43 AM
EVOJR$
Jan 27, 2008 03:54 AM
Hush
Australian Forum
Aug 24, 2004 12:43 PM
clappton
Site Feedback / Suggestions
Jun 25, 2004 09:57 AM
mattfl
Jun 14, 2004 11:20 PM
