Separating and inspecting the MHI housing??
Old Jan 18, 2017 | 01:04 AM
LakerRaider's Avatar
Hey everyone,
I just removed my stock IX turbo yesterday and will be sending it in to FP to have it built into a JB black. Got the vband clamp off , but I can't for the life of me separate the turbo from the housing to inspect the volute for cracks... Ive spent a long time with a flathead screwdriver , pb blaster, and applying pressure, but I don't want to damage the housing. I'm about ready to just ship it in the way it is and hope for the best. Any tips on removing the hot side, and on shipping the turbo? (Btw, this is my stock turbo that now has 120k miles, zero shaft play, awesome condition! Got the car in early 2008 with only 11k miles.)
Attached Thumbnails Separating and inspecting the MHI housing??-img_8964.png   Separating and inspecting the MHI housing??-img_8944.jpg
Old Jan 18, 2017 | 01:48 AM
deylag's Avatar
Yea looks like it might be seized due to rust. You can try to heat cycle it. Try spraying pb blaster and then heating it up with a heat gun. Once it starts to smoke you will know its getting hot. When you get it hot enough you can dump it into an ice bucket.
Old Jan 18, 2017 | 07:43 AM
DSMolition's Avatar
Most of the time they just need that initial jolt to start separating. I wouldn't use a flat head in chance you might bung up the band surface. I would try some heat and then use a dead blow on the housing. Just don't get carried away.
Old Jan 18, 2017 | 08:08 AM
kaj's Avatar
kaj
After getting the v-band off, I just tapped it with a mallet. Well.. more like whacked it. Just be careful and you won't hurt anything.
Old Jan 18, 2017 | 08:52 AM
EvoooB's Avatar
Here's your answer! Its a chunk of cast steel, your not going to hurt it... just use common sense with what size hammer you use and how hard your hitting. Try to hit it at points all around so it backs off evenly and not crooked
Old Jan 18, 2017 | 09:04 AM
kaj's Avatar
kaj
Deadblow is the best.. my rubber/poly one did the job, though.
Old Jan 18, 2017 | 10:02 AM
4b11slayer's Avatar
Rubber mallet
Old Jan 18, 2017 | 11:16 AM
LetsGetThisDone's Avatar
Deadblow hammer. If you don't have one, buy one. It's a great tool to have.
Old Jan 18, 2017 | 01:12 PM
lonestarr20's Avatar
Go to the hardware store
Buy a brass putty knife
Find a hammer
Tap the seam in the 12,3,6, and 9 o clock position
Take your time, it will separate
The brass won't damage anything, peace
Old Jan 18, 2017 | 11:21 PM
Pb blaster has been sprayed on. Let's see if I can get it apart . Rubber mallet, dead blow, or the putty knife.
Old Jan 20, 2017 | 10:49 PM
Got it, thanks guys!
€vo!utioN
Aug 31, 2015 05:14 PM
impact blue
Mar 1, 2012 07:12 PM
gvr4737
Apr 13, 2010 12:49 PM
RalliArtEvoVIII
19
Feb 25, 2005 09:32 PM
