Service Engine Soon
Old Mar 17, 2017 | 03:42 PM
cts4g63's Avatar
Service Engine Soon
57k, full bolt on, STM tuned.
Service Engine Soon light has come on for a second time now in two weeks. Will AutoZone scanning bring up any codes?
Any ideas? Plugs? MAF? o2?
Old Mar 17, 2017 | 05:33 PM
cts4g63's Avatar
P0401 EGR, must be a hose.
Old Mar 17, 2017 | 07:23 PM
4G63_EVO's Avatar
check hose under intake mani, I had this often with my old car
Old Mar 17, 2017 | 07:33 PM
barneyb's Avatar
When the engine conditions are right (vehicle speed, throttle position, coolant temperature) the ECU does a test by opening and closing the EGR valve. With the EGR valve open the pressure in the manifold should increase about 0.5 psi. This is measured by the manifold pressure sensor. So, the following things could cause your car to flunk the test.....
1. EGR valve stuck in the closed position or plugged up.
2. As you mentioned, loss of vacuum.
3. Malfunction of the EGR solenoid that supplies vacuum to the valve. This gizmo is located on the manifold stay.
4. Something is wrong with the wiring to or electrical plug on the solenoid.
5. The pressure sensor on the manifold has failed.
Old Mar 17, 2017 | 08:08 PM
deremer71's Avatar
Mine threw the same code and it ended up being a vacuum line disconnected. I think there are three that come off the EGR but not 100 percent. Worth a check anyhow.
Az3ar
Jun 16, 2004 11:05 PM
Lancer408
Lancer Troubleshooting
46
Sep 30, 2003 07:07 PM
ChillinEvoVIII
10
Jun 28, 2003 01:45 PM
IS2000
14
Jun 9, 2003 08:25 AM
BostonLancer
10
Aug 26, 2002 05:41 PM
