Evo 8 no start
Old Apr 7, 2017 | 09:05 AM
4G63_EVO's Avatar
Originally Posted by Stark_Tech
I originally cut them free of the box, and twisted them together, and heat shrinked it to cap it off. I'm guessing they came apart or something when I took the box out the other day (maybe I bumped it or pulled on it). They were loose under the heat shrink so...took it inside and soldered all 5 wires together good'n tight. Tomorrow I will hook up the battery charger and see if the car will run now...
The anticipation is killing me!
Old Apr 7, 2017 | 08:24 PM
Stark_Tech's Avatar
Lmao! Me too...just got my hands on a charger. Gonna leave it on tonight and try to crank in the morning...
Old Apr 9, 2017 | 10:46 AM
Stark_Tech's Avatar
Ok guys.
I soldered those wires all together solid this time, put the plug back in and it fired right up the first time I hit the key. Hopefully this will help the next guy!
Idled like it normally does. No issues there.
I took it down the road, I mashed the gas a little to try and build about 5lbs and when I did, the car felt like it was bogging down and choking and then I let off the gas and resumed driving under no boost. The sound the bov makes sounded way different and choked off sounding. I went down, made a u turn and while coming back to my house I mashed the gas one more time and this time it starting building boost and when it got just under 5 I let off and the bov made its normal noise...
Got to my driveway, pulled in, pulled back out, drove down again and it did the exact same thing. First time I try, it bogs when you try to start building anything, second time I tried it on the way back, it started building boost and the bov let off as normal.
It must be something simple...I'm thinking perhaps a hose somewhere is not right, or maybe when the guy coated the waste gate actuator maybe it's stuck shut? Would that cause this? Tomorrow morning I will remove the pin on there and check to see if the arm moves freely. It's obviously something just not working right in my turbo system. But we solved the first problem! lol
Old Apr 9, 2017 | 11:03 AM
4G63_EVO's Avatar
Ok guys.
Woohoo! Glad I could help
Old Apr 10, 2017 | 11:59 AM
Stark_Tech's Avatar
Thanks dude (and everybody who responded).
I drove it around a bit again this morning.
When I first got in and cranked it up, I sat there and tried to rev the engine a few times. When doing this, it was as if it was choking and bogging. Then I revved it a few times and it seemed fine. Took it out on the road and boosted it 5 or 6 times near my house, ran flawless.
I'll try to drive it a few more times this week just to see if it stops doing that.
In the meantime, feel free to chime in with things that could potentially be causing this symptom.
Old Apr 10, 2017 | 12:38 PM
4G63_EVO's Avatar
I think it needs a tune no?
Old Apr 10, 2017 | 01:07 PM
Stark_Tech's Avatar
It's been tuned, about a year ago. It was running perfectly fine before I took the turbo off to coat it. Just something somewhere isn't right I guess.
Old Apr 10, 2017 | 02:11 PM
4G63_EVO's Avatar
but it was tuned on the high z? If it was it was with an improper resistor pack delete. They are probably flowing a bit different now
Old Apr 10, 2017 | 03:48 PM
Stark_Tech's Avatar
I put cams in it, a better turbo, fuel injectors, ect, and I bypassed that resistor. Then got it tuned. Should be no change at all.
Old Apr 10, 2017 | 04:59 PM
4G63_EVO's Avatar
but it wasnt bypassed correctly right? The wires were just cut? Could have changed how the injectors are firing causing the bit of bogging you were noticing
Old Apr 10, 2017 | 06:37 PM
Stark_Tech's Avatar
All the wires were bare and twisted together the first time so it was making good contact, I think I just pulled them apart working on the car this time.
Old Apr 10, 2017 | 10:16 PM
4G63_EVO's Avatar
ah ok, well keep us posted if anything else arises
Old Apr 11, 2017 | 10:59 AM
Stark_Tech's Avatar
I drove it to work today, about a half hour trip. Drove great just as before. Maybe I just needed to clear its sinuses.
BrandonIX
56
Jun 17, 2018 07:20 PM
Braydo25
Jul 14, 2010 11:56 AM
geevolution
Dec 31, 2009 05:31 PM
WongFu
AEM EMS
10
Nov 29, 2007 01:28 PM
