considering adding trans-temp sensor/gauge to evo-IX 6-speed -has this been done?
Old Oct 15, 2017 | 02:16 PM
Jp7's Avatar
Jp7
I'm considering adding a trans-temp sensor to my Evo IX 6-speed. I'm not sure if anyone has done this before, but I did search and came up with nothing.
It would be something like this:
I assume the sending unit would look something like this:
Can anyone provide feedback or suggestions?
Old Oct 15, 2017 | 10:45 PM
Laxman's Avatar
I think kaj might have done this. I will be later on as well
Old Oct 18, 2017 | 10:39 PM
Jp7's Avatar
Jp7
bump for answers or opinions
Old Oct 21, 2017 | 09:01 AM
Teal2nnr's Avatar
No harm in it. If i kept my 6 speed i was going to try to install a pump and oil cooler as well.
Old Oct 21, 2017 | 02:30 PM
iLLevo_'s Avatar
I can't see it hurting as long as wherever that sensor is tapped into doesn't leak or take away from the structural integrity of the housing
Old Oct 21, 2017 | 08:51 PM
Jp7's Avatar
Jp7
That's the thing- I want to use a factory hole or plug. I really don't want to do any drilling or tapping.
Old Nov 13, 2017 | 06:24 AM
acid7711's Avatar
There won't be any harm in doing so, but honestly, it's kind of a waste.
I work for one of the larger aftermarket gauge companies. We get this question quite often "I want to put a transmission temp gauge on my manual transmission - Should I and if so, where do I put it?"
Generally speaking, in the pan if you don't already have a port. However, at the end of the day, manual transmission temps just don't (generally) get up to where the autos do. Autos have higher pressures and more friction when compared to a manual trans, and thus the very high temps that manual transmissions don't (typically) see.
Now, this isn't to say the gauge is useless or isn't going to be beneficial to you. Keeping an eye on temps is always a good thing, there are no downsides to monitoring it, as long as it's installed properly, not impeding any fluid flow anywhere, and obviously not leaking. I'm just saying keep your expectations for it in line with what you're likely going to experience in real life, as honestly, the gauge probably won't move around a whole lot.
Old Nov 13, 2017 | 12:55 PM
LetsGetThisDone's Avatar
Unless you do HPDE track days with the car, this is a waste of time/money.
PatricksEvilEvo
15
Aug 10, 2012 05:28 AM
stareandwonder
11
Sep 22, 2009 10:33 PM
italianevo88
Sep 7, 2009 09:28 AM
extremier
Apr 23, 2008 05:21 PM
JF1GD2
122
Mar 5, 2005 11:21 AM
