In dash double din w ability to view Evo scan and listen to music/radio?
Old Dec 2, 2017 | 12:30 PM
  #31
Biggiesacks's Avatar
oil pressure isn't even wired into the ecu (that i know of) so you wouldn't be able to see that through OBDII or MUTIII. If the bluetooth dongle has analog inputs though you could wire the pressure sensor into it and probably set up the formulas in the torque app. Disclaimer I don't have nor have ever used the torque app so i dont know if you can custom define stuff like in say evoscan.
Or if you wanted to you could probably hijack an analog channel to the ecu like they do with the fuel temp sensor for SD conversion.
Old Dec 2, 2017 | 12:34 PM
  #32
kyoo's Avatar
oh ok - evoscan can't see oil pressure either then?
Old Dec 2, 2017 | 12:42 PM
  #33
nope, Hamish did have a special cable with his stand alone though that had a few Analog inputs that you could custom define. I don't think he ever offered that cable solo though.
Old Dec 2, 2017 | 12:48 PM
  #34
kyoo's Avatar
eh, then there's nothing really that torque can't do for my purposes. I can still monitor coolant temp, rpms, etc. i guess for logging knock and stuff, you'll still need evoscan, but at the least my CEL will flash if I see knock.
https://lh3.ggpht.com/IElU7AcmrAvI8y...yu1jEg=h900-rw
Old Dec 9, 2017 | 07:40 PM
  #35
Timothy Kramer's Avatar
stand-alone unit =)
Old Dec 9, 2017 | 07:48 PM
  #36
iLLevo_'s Avatar
Stand alone then what to monitor live?
Old Dec 10, 2017 | 06:41 AM
  #37
Teal2nnr's Avatar
Ummmm laptop......glued to the dash?
Old Dec 10, 2017 | 11:31 AM
  #38
RazorLab's Avatar
i know torque won't do the logging evoscan does, but i'm curious about using torque & and obdlink bt tool. It'll at least show temps and stuff but IDK if it will show oil pressure, which is what I'm most curious about
OEM sensor is just a pressure switch, not a linear pressure sensor.
On this topic. I always wish I had something like this in my CT9A at the time. Now that I have a CZ4A, I was able to make this dream come true pretty easily.
Integrated android head unit with wifi streaming of all ECU sensors + 7 analog sensors (Fuel Pressure, Oil Pressure, Oil Temp, Crankcase Pressure, Boost Pressure, Surge tank Pressure, Wideband) Logs to SD Card and real-time to headunit.
Old Dec 10, 2017 | 03:18 PM
  #39
kyoo's Avatar
seems to be some hardware/wiring required with that? torque does it through bluetooth obd2.. not as pretty as the racecapture app but idk that racecapture can read from the obd2, at least for the inputs that obd2 can read
Old Dec 10, 2017 | 04:13 PM
  #40
RazorLab's Avatar
Yes I am using Racecapture Pro 2 which reads all ECU data via CAN/OBD2 plus all the external analog sensors and streams it via Wifi to the Android head unit.
It also has GPS and lap timing as well.
Old Dec 11, 2017 | 06:37 AM
  #41
kyoo's Avatar
oh so it does read via obd2 sensor?
this is the one i use:
Amazon Amazon
- will it read off of that then?
Old Dec 11, 2017 | 07:16 AM
  #42
RazorLab's Avatar
https://www.amazon.com/ScanTool-4261...dp/B006NZTZLQ/ - will it read off of that then?
The racecapture unit has a hard connection to the ECU and CAN network via the OBD2 port. Anything the ECU outputs, it can read.
Old Dec 11, 2017 | 07:25 AM
  #43
kyoo's Avatar
ahh got it. i guess i was confused, thought it was an app by itself, looks like it's an actual hardware data logging system
Old Dec 11, 2017 | 07:31 AM
  #44
RazorLab's Avatar
Yes. Racecapture app on android head unit receiving data via WiFi from the racecapture unit.
Old Dec 20, 2017 | 03:20 PM
  #45
supeazn's Avatar
Originally Posted by miragevo
Yes, I purchased this above.... for the box and 7" HDMI Touchscreen....'m gutting the Rasberry PI and starting fresh with an ASRock H270M-ITX/ac LGA 1151 Intel H270 HDMI SATA 6Gb/s USB 3.1 Mini ITX Motherboard, Intel i7-7700 Kaby Lake Quad Core Processor 3.6GHz & Cooler Master Hyper 212 EVO RR-212E-20PK-R2 CPU Heatsink Cooler, Team T-Force DARK 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 2400 Memory, TOSHIBA 512GB Solid State Drive M.2 2280 PCIe NVMe, MeLE F10 Deluxe 2.4GHz Wireless Fly Air Mouse Keyboard Controller ...plus a bunch of other stuff. Going to run windows 10 and GPS. Just waiting on a few things to arrive...Can you say...The Learning Curve.....it's gonna be fun!
Let me know how this works for you.
