In dash double din w ability to view Evo scan and listen to music/radio?
Old Sep 19, 2019 | 12:32 AM
  #91
fireroasted's Avatar
Originally Posted by razorlab
OEM sensor is just a pressure switch, not a linear pressure sensor.
On this topic. I always wish I had something like this in my CT9A at the time. Now that I have a CZ4A, I was able to make this dream come true pretty easily.
Integrated android head unit with wifi streaming of all ECU sensors + 7 analog sensors (Fuel Pressure, Oil Pressure, Oil Temp, Crankcase Pressure, Boost Pressure, Surge tank Pressure, Wideband) Logs to SD Card and real-time to headunit.
http://www.youtube.com/watch?v=zXqx5RwC-BA
http://www.youtube.com/watch?v=dltIClLydzk&t=
I know this thread is a bit old, but I am looking to build an in dash setup to simplify on track logging without having a laptop under my seat. I like razor's setup here, and wondering what the current suggestions is for the Android Head unit that can support something like the race logic box, or if there is something that can just run EvoScan directly as another option. I big touchscreen to provide audio/media functions as well is key.
M
Old Mar 10, 2023 | 03:35 PM
  #92
WalkerWakaWaka's Avatar
5 Year Member
I engineered a solution to have EvoScan operate automatically on an integrated computer through any HDMI input capable head unit. I also created professional looking EvoScan custom gauges and a gauge layout to work with it. Maybe others can benefit from my work. Below is a link to the forum post with more details, pics, and the files needed to do this yourself. Any questions/comments should be directed to the main post please.
Note: You could also deploy this solution if you wanted to run other types of content from a computer; for example, to re-flash your ECU. You can also grab the gauges content for EvoScan to use for your own custom layout.
https://www.evolutionm.net/forums/ev...l#post11967058
Old Mar 10, 2023 | 04:29 PM
  #93
Thanks for updating here. I still haven't done anything about this, but very interested. Still have the EVO, and will surely be burried with it. I'll check out the detailed instructions you have on that other thread. Thanks for sharing all that!
Evo8yu
Sep 11, 2014 09:56 AM
BlackSE
Oct 23, 2010 09:06 AM
