Block and head machining.
Old Dec 4, 2020 | 05:22 PM
EvolutionCP9AV's Avatar
What do you guys usually pay to get the head and block machined?just wanted to compare the quote I got.
thank you.
Old Dec 6, 2020 | 02:08 PM
blackline's Avatar
5 Year Member
It would all depend on what you're getting done.
Old Dec 7, 2020 | 11:52 AM
LetsGetThisDone's Avatar
Depends on what you're getting done.
Short block machine work is usually around $1k though. hot tank block, bore/hone cylinders to size, deck surface, align hone mains/polish crank mains to set main bearing clearance, hone rods/polish crank journals to set rod bearing clearance, check clearance of wrist pins in small end of rod/hone as needed, balance rotating assembly, hone hub for ATI damper to fit crank snout, install rear balance shaft bearings rolled to block oil ports, final hot tank of block post machine work.
Old Dec 7, 2020 | 11:55 AM
wow..thank you,best reply.
I guess I didn't realize how much work goes in to it for the whole build.
Old Dec 7, 2020 | 12:59 PM
RallySport9's Avatar
You may not need all of these services though, whats involved in the build? Is it just as simple as swapping out rods/pistons or a complete engine rebuild? You may be able to get away with just decking head, honing bores for example.
Old Dec 7, 2020 | 01:05 PM
It's a complete rebuild.
the builder is awesome...I am just trying to figure out the prices for everything at the moment.
as far as I can see everything checks out.
Nothing is free in life 😉
Old Dec 9, 2020 | 07:15 AM
blackline's Avatar
5 Year Member
Just wondering, what you're building with a 86.5MM headgasket and H beam rods?
Old Dec 14, 2020 | 12:11 AM
sorry for late reply...
4g64 block
crisdiarata
Jun 4, 2014 12:37 PM
FL_SilverEvo8
23
Oct 9, 2009 04:15 PM
evodrivesme
Mar 24, 2008 09:07 AM
PATRICK B.
Nov 10, 2007 02:03 PM
