Evo 8 which wires to use for immoblizer cut ?
Old Sep 10, 2005 | 11:52 PM
blackfly's Avatar
Hey guys - I'm about to install an alarm into my evo 8. I have got plenty of experience install alarm and used to have my own biusiness a few years ago.
Got all the wires sussed however can someone tell me the cuts for the immoblisers. The ignition and starter motor are simple, but does anyone know the wire colours and locations of the fuel pump and ecu ? I want to make it real hard to steal.
On my evo 4 when I took the alarm out they had cut the starter and what looked to be the fuel pump wire. It was a quite a thick black wire running from the drivers kickpanel to the rear down the drivers side, I think it had a white trace ? Can anyone confirm what they are for an 8. Also I am aware that the 8 should have a factory immobliser which proignition or starter so probably one of the other cuts is all that I need.
If anyone can help me with these two wires (ECU and Fuel Pump) please advise, thanks -
Old Sep 11, 2005 | 05:27 AM
mrbkkt1's Avatar
Click here,
hope that helps!
Old Sep 11, 2005 | 05:39 AM
kmcconn9's Avatar
What immobilizers are you talking about? All you need to do to have a steal safe car is install a starter kill, and hide the immobilizer bypass module realy well. Most of the DEI alarms also have AED (automatic engine dissable). This feature will cut the starter wire in half 30 seconds after the car has been shut off and the ket taken out of the ignition. Just turn this feature on as well. Your car will not be going anywhere, except on a roll-back..
Old Sep 11, 2005 | 05:46 AM
mrbkkt1's Avatar
he wants to install an auto start, not disable the car.
well i hope so or else it's a useless endeavor.
besides people tow cars to steal them nowadays.
Old Sep 11, 2005 | 05:49 AM
mrbkkt1's Avatar
Enjoy, use it wisely . (Mods might want to make it a sticky).......
wire / color / polarity / location....
12volts white + ignition harness
Starter black/yellow + ignition harness
Ignition black/white + ignition harness
Accessory blue/black + ignition harness
Second Accessory blue/white + ignition harness
Notes: Not required for remote start.
Keysense blue ignition harness
Notes: The wire rests at ground with the key out of the ignition cylinder, and goes to an open circuit when the key is inserted.
Power Lock purple - driver kick, door harness
Power Unlock lt. green - driver kick, door harness
Lock Motor blue/red 5wi driver kick, door harness
Unlock Motor white 5wi driver kick, door harness
Parking Lights+ grn/yel (L), grn/wht (R) + wht plug bottom of fuse box
Hazards white - hazard switch
Turn Signal(L) lt. green or white/blue + driver kick, harness to rear
Turn Signal(R) yellow + driver kick, harness to rear
Reverse Light brown + driver kick, harness to rear
Door Trigger white - wht plug bottom of fuse box
Dome Supervision use door trigger
Trunk/Hatch Pin green/orange - light in trunk
Factory Alarm Arm N/A
Factory Alarm Disarm gray - driver kick, door harness
Tachometer black/yellow or black/green ac either ignition coil
Brake Wire green + brake pedal switch
Parking Brake blue/red - parking brake switch
Horn Trigger blue/red or red - steering column
Notes: It is blue/red on the standard models and red on the Evolution VIII models.
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: DEI 555U (requires a programed key for remotestart)
Notes: Only the Evolution VIII models have the immobilizer.
__________________
I install for you turbo upgrades, IC piping, exhuasts,suspension upgrades, boost controllers, gauges, and all other electronics........
aim- spoolinb
much thanks to benji's post which was very helpful in retrofitting an evo6 turbotimer harness to work in an evo8.
Old Sep 11, 2005 | 06:45 AM
kmcconn9's Avatar
yes I understand this as I am an installer...My question was why do you need to know where the ecu and fuel pump wires are?
Old Sep 11, 2005 | 06:48 AM
kmcconn9's Avatar
__________________
aim- spoolinb
I guess this is good information considering that it is copied right off of directed electronics website...
Old Sep 11, 2005 | 07:06 AM
kmcconn9's Avatar
ok here are all of the wires and thier locations for a security system, remote start, and/or keyless entry system...
*12volts-white (40A)-Main Ignition Harness
*Starter-black/yellow-Main Ignition Harness
*Ignition-Black/white-Main Ignition Harness
*Accessory-blue/black-Main Ignition Harness
*Second Accessory-blue/white-Main Ignition Harness
*Keysense-blue-ETACS ECU (pin 30)
*Power Lock-purple-ETACS ECU (pin33)
*Power Unlock-light green-ETACS ECU (pin34)
*Parking Lights-green/yellow (L), green/white (R)-white plug in drivers kick, 25 pin plug (pins 5 & 16)
*Hazards-white-ETACS ECU (pin 25)
*Door Trigger-blue-white plug directly below fuse box
*Dome supervision-use door trigger wire
*Trunk Pin-green/orange-light in trunk
*Factory Alarm Disarm-gray-ETACS ECU (pin25)
*Tach-black/green or black/yellow-either coil
*Brake Switch-green-drivers kick panel (white plug beside the black plug)
*Parking Brake-blue/red-at parking brake switch
~The ETACS ECU is attached to the back of the fuse panel under the drivers side dash. It is the red ECU that has two main connectors on it.
This is everything you will need for a complete, and successful install...
Old Sep 11, 2005 | 10:20 AM
VTECH8TR's Avatar
Man every wire needed to tap into is here .
Thanks guys
Old Sep 12, 2005 | 12:48 AM
blackfly's Avatar
hey just for extra security I would like to immoblise the fuel pump at least. It is easy for someone who knows about alarms to find the starter and accessory wire behind the key or just up under the dash and reconnect them, it is alot harder for them to trace a black relay cut off wire which goes brain the alarms brain and sneaks its way down the drivers kick and is cut part of the way doen the car in the loom. I'll find it easy enought by lifting the back seat and looking at whatr wires are to the fuel pump and then finding the wire which starts as 12volts and then stops when car is turnied on and then runs constantly when the car is running, I think it is black with a yellow trace from memory ? though it might help to know rather than to have to go through this process and search for it.
Hey thanks for the wire diagrams dudes, does anyone know about the wire colour ???
Old Feb 22, 2010 | 11:00 PM
bmxer4it's Avatar
bump. Where and what color is the Fuel pump wire. I need it for a different use.
Old Feb 23, 2010 | 11:04 AM
mitsuEVO8kid's Avatar
^^to the above diagrams, I recommend using them as a guideline and STILL test to be sure that they are the correct wires. I have seen a few models with different colors.
evoniners
11
Oct 11, 2015 10:51 AM
wazzelby
Jul 18, 2015 05:46 PM
Leon5366
Mar 28, 2013 08:11 AM
danmark
10
Dec 31, 2012 10:17 AM
blackfly
Aug 15, 2012 06:05 AM
