ams vsr intake manifold
Old Dec 29, 2006 | 09:12 AM
05graphiteMR's Avatar
searched but no luck, trying to install the ams intake manifold but have run into a couple of problems. i am also installing an AEM ecu and am not sure what sensors i can eliminate (emissions etc) since there are no vacuum lines on the tb, it appears i may be able to get rid of a couple, but the vent for the fuel tank i am not sure what to do with - do i just route it back into the manifold?
also, the alternator bracket - it is supposed to bolt on the back of the manifold flange, but if i do the alt with not be in the right spot and i can't bolt it to the side of the head. do i need to hack it up or is there supposed to be another bracket with the mani?
Old Jan 1, 2007 | 09:24 AM
Evo VIII 4G63's Avatar
I would like to know also
Old Jan 1, 2007 | 11:01 AM
DWAIST's Avatar
i do remember having the same problem on another evo i helped my buddy with. i think all we had to do is cut the "tacked" nut off the back of the alternator bracket and slot it enough to line up.
i didn't hang around long enough for the vaccum line install, but i would definately make provisions for the brake booster, boost reference, bov, and map sensor. the other lines i wouldn't be concerned with when using an aem.
i don't know if this helps any but i'll get with my buddy and i'll post back up for you!
Old Jan 1, 2007 | 12:44 PM
9sec9's Avatar
Doesn't AMS send any instuctions with this manifold? If this is the 1000$ manifold, how much could 2 sheets of instructions/pictures possible cost? I guess this is secret too, just like actual results.
Old Jan 2, 2007 | 03:50 AM
i bought it used, ams was closed fri and the weekend so i have to call them this afternoon to see if they do have something like that or possibly a mounting kit that i can get from them
Old Jan 2, 2007 | 09:45 AM
AutoMotoSports's Avatar
shoot me an email and I will send over the instructions for you
Eric
Old Jan 3, 2007 | 04:02 AM
msg sent!
thanks eric
Old Mar 12, 2007 | 12:34 PM
johnjonfenomeno's Avatar
msg sent for instructions also
Blue Evo 8
21
Dec 6, 2016 01:06 PM
Ivan@AMS
Automotosports - Illinois
87
Jun 3, 2014 08:16 AM
joseph143
Feb 19, 2014 07:42 AM
SmokingTires
Jan 30, 2012 08:35 PM
Tevenor
16
Apr 22, 2008 04:56 PM
