Magnus v5 Installation on an Evo 9
Old Jan 15, 2011 | 12:45 PM
  #31
honey on boost's Avatar
Awesome Write up. Finally got to use it
Old Mar 8, 2011 | 10:49 AM
  #32
Mike01gsr's Avatar
Awesome write up! I'm finishing up my install this weekend. Two questions. How did you go about lengthening the brake booster line? Did you just let the line coming from the charcoal casister (evap) vent to atmosphere now? Any help would be greatly appreciated!
Thanks!
Old Mar 8, 2011 | 03:26 PM
  #33
boostedwrx's Avatar
^ if you use the vacuum source closest the brake booster (on the V5) you shouildn't have to lengthen the booster line.
Old May 29, 2011 | 01:47 PM
  #34
h13cofrei's Avatar
Best write up I've seen. Props, I got lost once I noticed there was no puka for one of the sensors ahaha I wish i improvised the same way he did. Looks ALOT easier. Super Awesome Thread
Old Jun 27, 2011 | 12:50 PM
  #35
Lukelis's Avatar
where did you connect the other end of the positive crankcase ventilation 2 or rocker cover pcv valve??? thanks
Old Dec 26, 2015 | 02:41 PM
  #36
SWOLN's Avatar
Great write up. I agree the the altenator bracket needs to be cut down on the IX. I have not had the to cut the MIVEC flange near the feed as of yet, but maybe it's because the phenolic spacer is a little thicker than the normal white plastic one,and in turn making space.
Old Feb 21, 2017 | 09:23 PM
  #37
supersupra's Avatar
What does the Periphery bits change do? On the 13,14, and 15 bits, is it Evap, FPR, and EGR disable?
Does the tune needs to be changed with the Magnus V5 install?
Old Feb 22, 2017 | 06:06 AM
  #38
SWOLN's Avatar
https://www.evolutionm.net/forums/ev...-canister.html
Read that thread. It should lead you down the right path.
giumela
293
Aug 22, 2017 08:29 AM
Anubis18
For Sale - Cars For Sale
16
Apr 19, 2016 08:00 AM
2bar_evo
Midwest Region
Apr 3, 2016 05:09 PM
Madsta
Mar 22, 2016 09:02 PM
evo9guy
58
Feb 11, 2016 06:34 PM
