Rear Diff fluid change
Old Jan 4, 2010 | 01:59 PM
  #46
Slick-IX's Avatar
Originally Posted by LakerRaider
i want to do this by reversing onto ramps, but would all the oil drain if the car is raised from the rear?
i doubt it, the plug is located at the back, kindof what i show below (side view of rear differential lol) F=fill plug, D=drain plug, A=antiroll bar
.__
A..F
....|_D____________/
so if lifted from the back all the fluid will go forth not coming towards the drain...
also it is recommended that the car is ~leveled when you fill it with the new oil.
Old Mar 12, 2010 | 03:58 AM
  #47
4G63 T's Avatar
Pics please where is Rear diff located at?
Old Mar 12, 2010 | 04:30 AM
  #48
yahu's Avatar
^see step 1 from the first post. In particular:
"...If you do not know what the rear diff looks like, I highly suggest not doing this yourself..."
It is in the rear of the car, located in a housing, and is there to provide drive power to both wheels. Follow the drive shaft back to where it connects to a housing between the 2 rear wheels.
Old Mar 12, 2010 | 05:26 PM
  #49
4G63 T's Avatar
lol..i've read it not much of help..more than you do!
Old Mar 12, 2010 | 06:56 PM
  #50
yahu's Avatar
^I'm not sure what you're saying.
Old Mar 13, 2010 | 04:23 AM
  #51
Fast_Freddie's Avatar
Veteran: Navy
Seriously guys if you have a hard time changing your oil do not try and do a fluid change on the rear diff, t-case, or tranny.
Old May 25, 2011 | 06:45 PM
  #52
son of krypton's Avatar
Bumping this thread. I guess it's a newbie question but do I need to replace the drain/fill gaskets with new ones? I'm planning on changing my rear diff fluid pretty soon.
Old May 25, 2011 | 10:20 PM
  #53
TommiM's Avatar
If they look pretty flattened down like they have been used and torqued down a lot then I wouldnt recommend it. Even so, they can still seal just fine. You can get away with re using them. I personally try to always get a fresh new one on though.
chaotichoax
32
Feb 11, 2020 09:00 PM
SleepySamurai13
Apr 28, 2017 05:04 AM
deylag
Evo X How Tos / Installations
Sep 28, 2016 08:13 PM
junk1337
60
Jul 22, 2016 03:27 PM
runny_yolk
Apr 12, 2004 08:09 PM
