How to connect stock fuel level sensor to AIM MXL Strada dash
Old Oct 13, 2011, 02:05 AM
evodziobak's Avatar
I installed my MXL Strada on an evo 8 with Vipec ECU. Everything works fine, the data is received by the dash thru RS232 and I managed to configure the dash the way I wanted. I just need some help connecting the stock fuel level sensor to the analog input of the dash. Did anyone attempt to do this on an evo 8? I would really appreciate some help. I connected the pin 51 from plug C-02 that normally connects to the stock gauge unit, which is the pin with signal from the stock fuel level sensor to Analog channel 1 input on the MXL but that does not work.
Old Oct 14, 2011, 05:41 AM
bwk
bwk's Avatar
easiest way is to order this
http://www.ironcanyonmotorsports.com...el-sender.html
Old Oct 14, 2011, 11:58 AM
evodziobak's Avatar
Originally Posted by bwk
thanks for the info! That's what I'll do. So the MXL can't read resistance change at all on the analog inputs?
Old Oct 14, 2011, 05:11 PM
bwk
bwk's Avatar
Nope.. you need to convert it to 0-5v
Old Jan 26, 2016, 04:24 AM
martinPL's Avatar
Link above is not working.
Could you please send me another?
LeXcite
Jan 17, 2022 08:05 PM
mrfred
May 1, 2020 10:16 AM
Snowman916
Aug 7, 2016 08:32 AM
supak111
Mar 14, 2016 09:10 PM
BTR
AEM EMS
Jan 31, 2016 10:11 PM
Quick Reply: How to connect stock fuel level sensor to AIM MXL Strada dash
