EVO Clutch Install, includes t-case removal and service manual links
Old Oct 24, 2006 | 01:12 PM
  #196
C6C6CH3vo's Avatar
OK, right now nothing is supporting the tranny except the dowel pins and main shaft, and nothing is supporting engine but the passenger mount. Engine is resting on a wood block and tranny is resting on floor jack.
My question is when I pull this mama out, where is the center of gravity? It needs to rotate CW to clear but I need to know what to expect when she's mine.
Thanks
Old Oct 24, 2006 | 02:12 PM
  #197
hondafan's Avatar
expect the heaviest tranny you've ever held in your life! i would say at least 150. i used an engine hoist with some ratchet straps to support it and not get crushed. most of the weight is away from the bellhousing though, if i had to estimate a center of gravity, i would say around where the shift selector is, that's a very rough estimate.
Old Oct 24, 2006 | 02:43 PM
  #198
C6C6CH3vo's Avatar
Thanks
Old Oct 25, 2006 | 12:37 PM
  #199
C6C6CH3vo's Avatar
It's not the weight it's the fact that you need to rotate it after free and pull forward, just finished pulling it today. I placed a 2.5 inch PVC cap to the shaft comming out which saved it from getting banged up.
One thing for sure, mine doesn't weigh 150lbs, more like 90lbs, still it would have been nice if it was 10lbs
Old Oct 25, 2006 | 06:38 PM
  #200
hondafan's Avatar
i've only done a 6-speed and i'm sure it's heavier, but i still figured the 5 was more than 90. that's about what a B-series honda trans weighs and you can manhandle those from the floor, no problem.
Old Oct 26, 2006 | 03:41 PM
  #201
C6C6CH3vo's Avatar
Allow me to eat those word's, I moved the tranny to an area to work on and that sucker is 120lbs for sure.
Anyhow, due to my compulsive nature I thought I should overhaul everything as well, ordered the two O-rings, felt washers, and bushings (if you need order #'s let me know) along with corroded bolts.
I highly suggest that you DO Not replace fork bushings - you will tear the fork races up, I had to resurface it from trying to replace them
Old Oct 26, 2006 | 04:37 PM
  #202
MitsuJoe's Avatar
Sure please post the part #'s and details of those parts.
And words don't taste good so don't eat them.
Old Oct 30, 2006 | 06:52 PM
  #203
C6C6CH3vo's Avatar
Tranfer case to Tranny has two O-rings, one tiny (11mm) and one big (82.7mm), MD743612 and MD727944
Felt gasket to release fork, MD749474
Release fork bushing, MR953913 (just use old ones - tough to remove)
Most aggravating part of the whole process was installing driver side TJ shaft into tranny (green thing that goes onto spline of shaft with two cirlips). No where to get a grip or get leverage. I had a less painfull time lifting tranny into place with a jack and piece of wood than this.
Old Jan 23, 2007 | 06:45 PM
  #204
slcEvo8's Avatar
Registered User
just used the write up to do the install. I can safely say it was not the fun thing to do AT ALL.....BUT very good learning experience.....car is put back together and running PERFECT...nothing to report yet. Also haveing a friend to help cut down alot of time. Thanks for the write up and all the help!
Old Jan 23, 2007 | 08:21 PM
  #205
MitsuJoe's Avatar
very cool! Glad I could you.
Old Mar 7, 2007 | 04:12 PM
  #206
FastAzzEvo's Avatar
we are in the middle of a MR clutch/flywheel install. We have a bay and a lift.
We thinking we do not have to take the rear mount off, bolts are a ***** to get to ..
Can we just take the cent bolt off and take the mount with the tranny? I think we can but won't know until we begin again tomorrow.
If not , whats the easiest way to get the two bottom bolts off that rear mount that is facing the rear of the car? The steering rack is in the way.
Long extentions?
Old Mar 7, 2007 | 04:43 PM
  #207
MitsuJoe's Avatar
It does not have to come out if you roll the tranny forward. Although with the larger MR trans I think you may not be able to do it this way. The best thing is to move the t-case out of the way and push the motor towards the front of the car and begin loosening the bolts. It has been a few months since I have done a clutch install although this should be how it is done.
Best of luck. PM me if you want my phone # and I will assist you over the phone if that helps.
Old Mar 7, 2007 | 05:19 PM
  #208
FastAzzEvo's Avatar
Thanks, that might work. We think if we swing the tranning forward enough it should clear. I think we will try it your way first.
I feel sorry for people that do it on their back, some of the bolts required long breaker bars.
Old Mar 7, 2007 | 06:25 PM
  #209
MitsuJoe's Avatar
Longer breaker bars? LOL...maybe busted knuckles or being the big dude that I am will work just fine...
Old Mar 7, 2007 | 06:27 PM
  #210
smokedmustang's Avatar
Joe is now back on my Christmas list!! GREAT JOB! Lots of Smart Evo guys from Michigan!
