EVO Clutch Install, includes t-case removal and service manual links
Old Apr 22, 2007 | 08:22 PM
  #256
MitsuJoe's Avatar
You should be fine. I think it is more of a precaution than a must,
Old May 12, 2007 | 06:44 AM
  #257
OtownEvo's Avatar
Ok everything is back from Shep will be reinstalling this weekend....been month for shep upgrades hope I remember how to put back together!
One question what kind of greese can i use on the clutch fork and cylynder looks dry???? After sitting for a month...
Will post some pictures later of this install....
Old May 12, 2007 | 04:09 PM
  #258
hondafan's Avatar
i just used some mobil1 synthetic grease that comes in a can, purple stuff.
Old May 13, 2007 | 09:52 AM
  #259
mitsuorder's Avatar
I second the mobil1 synthetic grease. Pretty cheap from what I remember and readily available.
Old May 13, 2007 | 12:47 PM
  #260
OtownEvo's Avatar
Ok got tranny Back on....
HOW do i recconnect the TOB????
Old May 13, 2007 | 05:17 PM
  #261
hondafan's Avatar
push the release fork over and it should snap right on if you assembled it right.
Old May 13, 2007 | 05:24 PM
  #262
evoone's Avatar
subscribed
Old May 13, 2007 | 05:33 PM
  #263
BaLListic_EVO's Avatar
yeah thats the first thing i do as soon as the trans has a bolt or two back in and is flush with the block just to make sure i dont need to take it back out!
Old May 14, 2007 | 05:58 AM
  #264
FastAzzEvo's Avatar
I don't think anyone mentioned this, but when doing a clutch install don't you have to clean out the bell housing and areas around where the clutch sits?
Someone said it was important to clean out grime, grease, etc. when doing the clutch install.
Old May 14, 2007 | 06:36 AM
  #265
MitsuJoe's Avatar
I just got done with my own and didnt clean it out. Although when I work on a customers car I typically spray it down with some brake cleaner and wipe it out. Not a must but why not when your in there..
Old May 14, 2007 | 07:16 AM
  #266
Mr. EvoVIII's Avatar
Could someone tell me where the bleeder screw for the ACD is at? I know I have to bleed the ACD after the install.
Old May 14, 2007 | 08:09 AM
  #267
hondafan's Avatar
on the bottom of the TC.
Old May 14, 2007 | 09:13 AM
  #268
OtownEvo's Avatar
Alright got the TOB in know stuck on getting rear mount lined up and Stud through......
Any advice on rear motor mount?
Old May 14, 2007 | 10:26 AM
  #269
FastAzzEvo's Avatar
someone from the top and someone on the bottom.
Use a strong flathead to get it lined up better.
Shouldn't take anymore than a few minutes.
Took me about 10mins that included figuring out the best way to get the bolt back through.
Good luck, I'm sure you can get it in.
Old May 14, 2007 | 12:56 PM
  #270
mitsuorder's Avatar
Might I suggest applying a bit of lube to the rear mount bushing's exposed sides before raising the subframe back up. The bushing rubber can put the assembly into a bind if it catches when going back into place. This can be a pain to correct after you've already got the subframe back into position.
