EVO Clutch Install, includes t-case removal and service manual links
Old Apr 13, 2007 | 09:55 PM
  #241
matej's Avatar
are there any pics on net what else must be removed and how to?
Old Apr 15, 2007 | 05:54 PM
  #242
Sapperhustler's Avatar
I used the evomoto write up and didn't have any problems. It shows everything to take off and is pretty F'in great. LOL. Definately take off the crossmember. I didn't completely remove the transfer case, but I just pushed it up out of the way and braced it so it wouldn't move and that was probably the best way to do it.
Old Apr 17, 2007 | 02:24 AM
  #243
diyath's Avatar
Originally Posted by Joe's_EVO8
Make sure there is not a 12 mm bolt by the starter still holding the trans to the car
Joe, Do you recon that this write up can be applied to an Evo VI as well? Or do you feel Evo VI clutch replacement steps will be a lot different?
Thanks
D.
Old Apr 17, 2007 | 02:28 AM
  #244
Hey guys,
I just installed my new clutch and everything went pretty smooth. I have everything back in the car and I fired it up tonight to see if everything was working correctly,.......... it's not.
My shifter linkage is where I have a problem. If you take it out of gear, the shifter dosen't want to return to center. If you move it left or right and let go of it, it just stays there, feels kind of stiff. It also will not engage into any other gear but 1st (I think it's first).
I'm thinking that I must have done something wrong on hooking my cables back up, but I think they are correct. I really think that part of my problem is this little white plastic piece. I don't think that it is on how it should be and I can't figure the little bastard out. LOL Could someone please post a pic of how their's is on their car or a diagram or something would be great. I've attached a pic of mine earlier in the thread so you can see how it is. It's wrong I'm pretty sure.
This is the only thing keeping me off of the road and it's killing me. I'm not positive this is what's causing my problem so please feel free to off other ideas to check. I appreciate anything you guys can help me with. Thanks in advance.
Old Apr 17, 2007 | 07:34 AM
  #245
hondafan's Avatar
Thanks
D.
i don't know for sure, but i'd say the steps for a VI would be closer to the steps for clutch replacement in a DSM or galant VR-4 since their engine/tranny is more similar than the VIII or IX.
Old Apr 17, 2007 | 09:14 AM
  #246
MitsuJoe's Avatar
Originally Posted by Sapperhustler
Hey guys,
If the white plastic piece does not sit right then you may have bent the shift brackets that the cables bolt to. You may be able to bend it back although your best bet is to try to get it warrantied or to but the new assembly.
Old Apr 17, 2007 | 09:15 AM
  #247
MitsuJoe's Avatar
Thanks
D.
I have never seen a Vi in person although the extensive underhood pictures I have seen tells me it should be VERY similar. Best of luck and please note the differences here.
Old Apr 17, 2007 | 11:55 AM
  #248
I'm pretty sure it's not bent. it's looks fine.................... how does that plastic ppiece sit on there?
Old Apr 17, 2007 | 08:32 PM
  #249
LOL Joe, you were right man. That linkage was bent. I took it off and looked at it and you could see a little bend. Nothing that a vice and hammer couldn't fix. Will probably order a new one next week just in case. Thanks for the tip man. Should have never doubted ya.
Old Apr 17, 2007 | 09:19 PM
  #250
MitsuJoe's Avatar
Hey no prob, I only know because I have done enough of these things!
Old Apr 21, 2007 | 05:54 AM
  #251
OtownEvo's Avatar
Quick Question when reinstalling everything do you grease the axle's and transfer case??? If so what do you use???
Also do you use lock blue stuff on all the bolts?<---Forget the real name just woke up.....
Old Apr 21, 2007 | 05:21 PM
  #252
hondafan's Avatar
i didn't, don't know if your technically supposed to, but it never popped up in any of the how-to's i've read.
Old Apr 21, 2007 | 05:31 PM
  #253
uglyevo's Avatar
great thread and cool write up
Old Apr 22, 2007 | 07:40 PM
  #254
MitsuJoe's Avatar
Only blue locktite on the flywheel to crank bolts. Everything else just put back together.
No grease on the axles. They will get lubrication from grease in the case.
Old Apr 22, 2007 | 08:13 PM
  #255
hondafan's Avatar
Only blue locktite on the flywheel to crank bolts. .
uh-oh! i didn't put it on mine, just torqued em to spec. wonder if this will lead to problems down the road? been in for about 8K so far with no issues.
