Mechanical o2 Fix
Old Apr 9, 2005 | 07:29 PM
  #46
ralliartracer's Avatar
Performed the fix today. Just goona wait for the light to shut off now. Im not too sure on how to reset the SES light. Is it just a fuse?
Old Apr 9, 2005 | 07:41 PM
  #47
Z_Lancer_Man's Avatar
You have to reset your ECU. The easiest way is to disconnect your negative terminal on the battery for 10 minutes and then reconnect. Your SES light will be off. Or you can go to Autozone and they'll clear your code for you.
Old Apr 10, 2005 | 06:57 PM
  #48
Thanks alot dude.
Old Apr 12, 2005 | 09:19 PM
  #49
03OZLancer's Avatar
I just did this and it works. I also have two extra anti-foulers if anyone wants to buy them...i alrady have it drilled out.
Old Apr 12, 2005 | 09:43 PM
  #50
LateBrakeU2's Avatar
Just did mine today-great website and thread guys
Old Apr 12, 2005 | 11:14 PM
  #51
Almost 2 months now - still no CEL!
Old Apr 13, 2005 | 02:30 PM
  #52
03OZLancer's Avatar
My theory is that if you get past a week without a CEL with the mechanical o2 fix then it will never come back. Before I did the fix I would always keep reseting the ECU and would never last more than a few days without a CEL. I think if you make it past a week you will never see it again.
Old Apr 14, 2005 | 07:22 PM
  #53
exhaust_note's Avatar
i did this and my Check engine light comes on every 80 miles....
Old Apr 17, 2005 | 12:56 PM
  #54
jerseyjap's Avatar
i just want to know does it really matter where you put the 2 anti foulers at? i mean these to get drilled on to the dp right? i am planing on buying a rrm dp in a few weeks so i just wanted to know as much as i can before i buy the dp. thanks
Old Apr 17, 2005 | 04:29 PM
  #55
otter's Avatar
EvoM Administrator
It goes onto your second O2 sensor that's on your midpipe, not the sensor that's on the downpipe. You'll remove the O2 sensor, install the undrilled then drilled anti-fouler, then finally the sensor, very easy. I have no CEL yet with this mod while using RRM's downpipe.
Old Apr 19, 2005 | 03:36 PM
  #56
cyberninja's Avatar
Whoever came out withthis idea for a 02 fix should be a evolutionm.net guru
Old Apr 22, 2005 | 06:33 PM
  #57
DjDoubt's Avatar
I just read this. My down pipe doesn't have a bung so where do I mount the spark plug foulers? Do you have any mor info on this? Do I install it on the cat? the first (pre)cat and o2 sensor was removed with my stock headers.
Now I don't have an evo but I have kamakazi Headers and down pipe trying to get the ses/cel off for Va State Inspection in 2 weeks
Old Apr 26, 2005 | 03:32 PM
  #58
Lancer7's Avatar
I went to buy some and noticed that there are two sizes. ther's a short on and a taller one. which one do I get and is this why it didn't work for some.
Old Apr 26, 2005 | 03:44 PM
  #59
I got the shorter ones I believe: #42002 Works great for me.
Old Apr 28, 2005 | 10:09 AM
  #60
Lancer7's Avatar
Whelp.... Got the shorter ones. Drove 50 miles, and the idiot light came on again.
