Mechanical o2 Fix
Old Feb 7, 2013 | 02:47 PM
  #121
Artificial256's Avatar
Talking code P0420
I installed the 2 non foulers and it worked for about 30mi but my cel came back on. Any suggestions if this code is something other than my o2 catching the cat being "bad" or should I try three foulers? Any help would be appreciated. I have the rrm headers with the cat.
Old Feb 7, 2013 | 04:01 PM
  #122
heel2toe's Avatar
Are you sure the only code you are throwing is p0420? If so then that code is strictly for the rear o2 sensor. Back in the day when I used the anti-fouler method I only needed one and it worked perfectly. Now I have the code cleared from my ecu so I dont have any installed.
Old Feb 7, 2013 | 05:19 PM
  #123
Yeah I had the P0177 too but I put new spark plugs cleaned my maf changed oil and my air filter. It got rid of that one. But the reason I was doing all this because I had to emissions test and I failed but I passed when I finished that work. Where could I get it removed?
Old Feb 10, 2013 | 02:45 PM
  #124
only code
Yeah the only code I'm throwing is the p0420 code. I got it checked today again. I tried one fouler i have one on there now.
trinydex
141
May 18, 2018 09:34 AM
antics22
Evo X How Tos / Installations
267
Dec 6, 2016 08:40 AM
500whp.com
87
May 31, 2016 01:30 PM
trinydex
Mar 29, 2007 05:46 PM
trinydex
Mar 29, 2007 05:38 PM
