Mechanical o2 Fix
Old May 2, 2005 | 08:09 AM
  #61
Evo8DownUnder's Avatar
bump - did you try it again with the longer ones?
Old May 2, 2005 | 09:52 AM
  #62
jdub24's Avatar
Fow what it's worth.......2,000+ miles since, and no return of the CEL. This fix works!
Old May 2, 2005 | 01:54 PM
  #63
bigjhoney's Avatar
Originally Posted by DjDoubt
I just read this. My down pipe doesn't have a bung so where do I mount the spark plug foulers? Do you have any mor info on this? Do I install it on the cat? the first (pre)cat and o2 sensor was removed with my stock headers.
Now I don't have an evo but I have kamakazi Headers and down pipe trying to get the ses/cel off for Va State Inspection in 2 weeks
It will only make a difference on the sensor after the cat (atleast in the evo).
Old May 3, 2005 | 10:09 AM
  #64
Lancer7's Avatar
I will in a little bit here. don't have much time for my car. got work, school, and a stereo install, an GF and a kid... no time
Old May 3, 2005 | 04:00 PM
  #65
Lancer7's Avatar
Okay I'm confused now. After several hundred miles of driving, my SES light just turned itself off today. I think it was in the middle of a drive, but I'm not sure 'cause I started to get used to it. My theory is, I reset the computer wrong. I know you can't just disconnect the battery for a second, because there are caps in the car that hold a charge. So I turn on the lights and try to start the car w/o the battery. This should open some crcuits and drain the charge right? I saw a post on here about letting the car sit for ten minutes. Perhaps that would have done differently. Either way, the lights off ...hope it doesn't come back.
Old May 3, 2005 | 04:22 PM
  #66
Z_Lancer_Man's Avatar
Yeah, just disconnecting the battery for 10 minutes works. Glad that the light came off.
Old May 5, 2005 | 09:20 AM
  #67
AlkalineTrio124's Avatar
Did this on mine... Worked for a while... but then the SES light returned...
I then tried using 1 fouler because I thought possibly that the 2nd O2 sensor was not reading ENOUGH... that didn't work...
I'm confused gonna try one last time to make this work, otherwise it's hi-flow cat for me!!!
Old May 5, 2005 | 09:25 AM
  #68
EVIL MR's Avatar
i am only using one and it have been 7k since
Old May 5, 2005 | 10:04 AM
  #69
Lancer7's Avatar
I gassed up three times before she shut off. thats about 700 miles. give it time before you give up. I've been 500 w/o SES light now. I doubt she's coming back.
Old May 5, 2005 | 12:20 PM
  #70
What happens is that the ECU runs different tests everytime we drive. The cat test, if failed, triggers the SES light. However, after triggering the light, the ECU continues to monitor the situation. When you add the foulers or what not, the ECU sees a change, but keeps the SES light for about 2-3 more test runs to make sure that the problem has indeed been corrected. This explains why ^^ had to drive about 700miles for his to go off - it took that many miles for him to go through enough drive cycles to convince the ECU that the Cat problem was fixed. Assuming he doesn't change anything, it should stay off indefinately
Old May 6, 2005 | 07:02 AM
  #71
Lancer7's Avatar
Came back on yesterday without my changing anything.
I'm completely lost
Old May 6, 2005 | 08:46 AM
  #72
Then perhaps, its still reading too much O2, try the longer foulers - both of them together. Thats what I have and over 2000 miles later, still no CEL.
Old May 6, 2005 | 02:55 PM
  #73
RallySport Direct's Avatar
Silver Sponsor
One part you may want to try is the GP Moto Oxygen sensor adaptor. It is basically a pre build fouler method of getting rid of the CEL. Check it out
http://www.rallysportdirect.com/shop...230d415cdd4f31
Ben
Old May 11, 2005 | 02:52 PM
  #74
Lancer7's Avatar
I lied. when I went to NAPA, I saw that there were two different sizes. I asked for the smaller ones. I went back to buy the other size and found that he actually gave me the larger ones.
So anyways, given what was said about possibly getting too much air, I decided to back it out some more. I've got two large and one small non-fouler. I'm at 400 miles with no problems yet. I guess you just have to play with it to find out what works for you since different mods will give different air flow.
Old May 11, 2005 | 03:39 PM
  #75
Very true ^^
