Mechanical o2 Fix
Old Nov 1, 2007 | 01:54 PM
  #106
EVO8emUp's Avatar
1. You will pass inspection.
2. You don't need 2 anti-foulers. If you drill the hole to 17/32, the space between the tip of the sensor and wall of the anti-fouler is so close that the fumes cant get to the element.
The hardest part is centering the hole perfectly so the sensor screws in.
I have a few of these already machined if someone is looking for one..
Old May 19, 2008 | 03:41 PM
  #107
blankito350's Avatar
i think i have to put 3 adapters because mine still "service engine soon" light on... and right now have two adapters..!! i need some help.. my RALLIART have INJEN, DOWNPIPE(custom), RRM PULLEY.... i have these codes on the scanner: "system too lean", and something about o2 sensor.... PLEASE!!! my car after installing the aftermarkets run worst than STOCK!!!! (dyno)
Stock: 149hp and 154tq
downpipe, injen, pulley: 150hp and 144tq
Old Jul 10, 2008 | 07:02 PM
  #108
Krazyloc's Avatar
o2 fix works great got my car in 2007 i put Road///Race Race Series Header/Downpipe, ROAD///RACE Ralliart Underdrive Pulley Kit, ROAD/RACE - Magnaflow Highflow Cat, ROAD/RACE MIVEC Engine Ported/Polished Intake Manifold, ROAD/RACE Piggy Back ECU Automatic Version 2 and cai all of this stuff run good
Old Jul 11, 2008 | 12:44 PM
  #109
Canada_Comp's Avatar
Works for me, I used both antifoulers, put 600 km on and no CEL. Did not have problems with clearance since the angle of the sensor was parallel to the ground. for custom mandrel bent exhaust system =)
Old Jul 13, 2008 | 06:24 AM
  #110
Krazyloc's Avatar
2 didn't work for me i had to use 3 42002
Old Jul 14, 2008 | 02:31 PM
  #111
Krazyloc's Avatar
so far so good i did 80 miles no cel or ses using 3 anti fouler #42002
Old Jul 14, 2008 | 02:56 PM
  #112
damstr's Avatar
I found that I had to reset my car a couple times before the CEL never came back. 15k later and no CEL.
Old Jul 16, 2008 | 04:34 PM
  #113
Krazyloc's Avatar
i am using 3 anti fouler #42002 i did a 114 miles no cel yet
Old Sep 10, 2008 | 11:37 AM
  #114
6one9EVO's Avatar
can someone post up some pics on how to do this?
Old Sep 24, 2008 | 02:51 PM
  #115
Spish's Avatar
I'm installing mine tomorrow and will post up some pics, its on a IX so I might have some clearance issues.
Old Mar 1, 2009 | 06:37 PM
  #116
DJJimGreen's Avatar
were pics ever taken for this install?
Old Mar 1, 2009 | 06:44 PM
  #117
19DB794's Avatar
I got a o2 simulator from Ebay and I've had it in for 5-600 miles and no CEL yet.
Old Mar 29, 2009 | 10:56 PM
  #118
krisdlm's Avatar
http://www.streettunedmotorsports.co...engine_fix.htm
just ordered this w/ a test pipe last wk. Hope it works!
Old Oct 4, 2009 | 10:32 AM
  #119
PlanoEvo's Avatar
Originally Posted by bigfishs
Apparently you can get one of these brass fittings from hardware stores, for cases in which your antifoulers make the o2 hit the body.
Fix provided by whtevo
I asked him where he got the fitting and he cant remember. If I get one, I will post it.
see bottom of page24 of
https://www.evolutionm.net/forums/sh...&page=24&pp=15
Anyone know what the 90 brass fitting is and where it can be found?
Old Oct 22, 2010 | 06:30 AM
  #120
turboart's Avatar
well im glad bluesky came through with his pics :scoffs sarcastically:
