how to remove floor carpet off Evo
Hey guys and gurus,
Does anyone know how to remove the dead pedal off the front driver's side so that I can remove the floor carpet? I took off the center nut behind its trim panel but still couldn't remove it. There seems to be a circle trim plate near the top but I could not seem to remove it. I looked at the Servicemanual and searched but no dice. Can anyone help? Thanks...
Theres a plastic cover that pops off, it has a screw under it. Also towards the top there is a black circular piece with a slot in it. That is basically a screw. What you do is remove the bolt under the cover then start rotating the top piece counter-clockwise while gently pulling the piece up and it will come off. That top plastic screw needs some pressure to start un-threading.
(just did this 2 nights ago)
Im trying to remove the dead pedal aswell and all I can see to remove is the big circle up top that has a slit.
I removed that, but all it shows is a stud. What else do I remove to get this damn false pedal off?
EGbeater
28
Jul 18, 2019 01:24 PM
SuperClydeFrog
Mar 20, 2016 06:13 AM
