Dyno Flash "E FLASH!" now available
Old Jun 29, 2006 | 12:31 AM
  #391
nj1266's Avatar
Originally Posted by stuttgart1
I just got my map from Al and the boost is set at 27 psi all the way, my car is stock except DP, test pipe and exhaust. Is it safe to run 27 psi boost? Thanks
NO IT IS NOT SAFE. You are in CA and we have 91 octane pee gas. The most you should run is 22 psi.
Old Jun 29, 2006 | 12:40 AM
  #392
Warrtalon's Avatar
How can the boost be set to 27psi by a flash? It doesn't even work like that. I don't believe that's possible...
Old Jun 29, 2006 | 12:49 AM
  #393
stuttgart1's Avatar
the boost limit is set to 319. 319 = 27 psi right?
Old Jun 29, 2006 | 12:51 AM
  #394
RazorLab's Avatar
boost limit is not the boost setting.
Old Jun 29, 2006 | 01:12 AM
  #395
Warrtalon's Avatar
No, crazy man.
Old Jun 29, 2006 | 04:56 AM
  #396
cfdfireman1's Avatar
Cool
What was the limit set at before you sent it in??
Old Jun 29, 2006 | 05:15 AM
  #397
laakness's Avatar
Al, sent you a reminder email. Haven't gotten my map
Old Jun 29, 2006 | 06:43 AM
  #398
mike1023's Avatar
Well went to the track with al flash and its slower then stock ecu. 1/8 7.9@88 1/4 12.4@111.89 well more or less the same as stock ecu but lol i dont get it i think i need a cumstom flash or somthing no one seems to beable to tune my car this is great al is the 2nd one trying and still can not seem to do it haha.
Old Jun 29, 2006 | 06:54 AM
  #399
justchil's Avatar
What were your times before? Do you have any logging equipment? What's so unique about your setup?
Old Jun 29, 2006 | 07:18 AM
  #400
fsugatorbait's Avatar
If you've had two different people attempt to tune your car with less than stellar results it's probably not the tuner.
Old Jun 29, 2006 | 07:33 AM
  #401
MalibuJack's Avatar
Its likely that the tune is on the safe side, therefore it runs the same or a little worse than the stock "Untuned" ECU.. My guess is your combination of mods on the stock ECU resulted in a low MAF reading, therefore causing your car to run lean and with more aggressive timing on the stock ECU.. I don't recall if you got your wideband in there.. But I'm certain if you logged the data that is what you'd see..
Old Jun 29, 2006 | 07:43 AM
  #402
dudical26's Avatar
I agree... the intake that was on the car was probably scewing your MAF readings....try hooking up the wideband to see how your AFR's are.
Old Jun 29, 2006 | 07:49 AM
  #403
mike1023's Avatar
i have diff thinking going to happen soon, so i will see what happens im going to get more mods for car, and see what happens, i think weak points, fmic, injectors, also cluch get those things and then get a custom tune.
last night runing the cluch was slipping all 1st gear,
stock ecu i got week befor last night was 12.3@111 so kind of same speed but still car should be trapping high and all. and i was an idot and didnt log anything.
im wonderting tho if i ran bad becasue of the weather, but every one else was runing same traps and all. maybe not. who knews.
Old Jun 29, 2006 | 08:28 AM
  #404
well well
If your clutch was slipping in first it's probably slipping in the higher gears also since there is more load there.
Old Jun 29, 2006 | 08:42 AM
  #405
dudical26's Avatar
was the weather different between your runs Yesterday and last week?
