Dyno Flash "E FLASH!" now available
Old Jun 24, 2006 | 03:19 PM
  #346
jroller's Avatar
Sweet I cant wait to get mine. soon,hopefully. I noticed that you said "maps from AL" did you get more than one? If so what would be the purpose? Incase your running race gas or somthing?
Old Jun 24, 2006 | 06:28 PM
  #347
kevdog458's Avatar
Each "flash" comes with several maps, fuel, timing, boost, etc.
Old Jun 26, 2006 | 11:04 AM
  #348
DynoFlash's Avatar
Just to clarify . . . .
The $49.99 E FLASH! is ONE map 0- you select your mods - octane and other details
Those who get a custom tuned reflash get multiple maps (if they want them) which include - valet map, stock map, pump gas 20 psi map and race gas high boost map
Old Jun 26, 2006 | 11:06 AM
  #349
DynoFlash's Avatar
Originally Posted by fsugatorbait
From what ive read Al does not make changes to the injector scaling, he makes the adjustments from the fuel table.
It really depends on the particular application and inector used
The scaling function of the Ecu Flash can be cofusing as the numbers given are just arbitrary conversions of the actual hexidecimal numbers
Old Jun 26, 2006 | 11:10 AM
  #350
DynoFlash's Avatar
Originally Posted by BoostFrenzy
This is *EXACTLY* why there's a large emphasis on YOUR car being tuned ON THE DYNO, with the TUNER in COMPLETE CONTROL of the situation... you get what you pay for first off and if you aren't able to do your own fine tuning and problem analysis/correction, this solution is NOT for you.
I don't have an EVO yet, but i'm a long time subaru performance enthusiast as well as hondas and dsms back in the day, I agree when the individual has the PROPER equipment (wideband/egt/datalogging software/means to edit the map) and an understanding of what to change to make it applicable to his/her car based off the data collected from above, something like this will work
but, the reality is, most people just want to pay a small fee for a free tune, flash it and go run 11s.... doesn't work that way
It seems to me if things aren't right, you should be collecting data and having these conversations directly w/ Al, not crapping up the forum saying he sucks.
This is what you would conclude comming from a general performance background
However, in the case of my base calibrations in 90% of cases they are very close to ideal as I set them up - the reason being is that I have tuned a huge volume of cars and the modifications are usually done in patterns
Most if not all of the people getting these maps will have no problem to just install the map and the car will drive dramatically better tahn with the stock mapping
Those who are doing do it yourself tuning will have a much easier time by using the maps provided
Old Jun 26, 2006 | 11:17 AM
  #351
laakness's Avatar
Al,
I had a custom tune from you a year ago and would like the update E-flash for the mods I have since added. I would also like the extra maps you mentioned a few posts back about vallet, race gas, etc if they are at no charge. I never got multiple maps originally.
I already sent my payment and mod list (93) octane on Friday last week and haven't heard back. Please advise.
Thanks, Mike Laak
Old Jun 26, 2006 | 11:29 AM
  #352
DynoFlash's Avatar
Originally Posted by mitsugsx
^Thanks for the concern... but none of the above. The car does not even idle with the new flash in it. Its basically this... the car pulled in fine.... the eflash was flashed...car runs like ****. End of story.
Yes, there was oil, but he already knew that.
What kind of injector scaling is everyone else running with anything larger than stock inj? Also, the car bogs at 2500 rpms. Ive never see a car do that unless it was getting demolished with too much fuel in the motor.
Anyone else have any ideas...cause i am deffinetaly out.
My suggestion is to NOT use the map I sent you
The map i sent you has working in several hundred similarly modified evos with same injectors
If it is running overyly rich in your car it is bizzare as the stock map will idle fine with the 680 injectors you have and your map is slightly leaner than stock
A few points that may result in this condition :
1 - You did not zero your SAFC
2 - Electrical problem or faile SAFC
3- Gross boost leak
4 - Injector leaking
5 - Other mechaincal issue which I can not diagnose without hands on car
Best of luck with your problem
Al
Old Jun 26, 2006 | 11:30 AM
  #353
DynoFlash's Avatar
Originally Posted by laakness
Al,
Thanks, Mike Laak
I will be getting to you by end of today or tomorrow
I was tuning all weekend in SLC Utah and now I am air port and unable to open my spare lap top to trasnfer data
  #354
laakness's Avatar
No problem, thanks.
Old Jun 26, 2006 | 11:56 AM
  #355
emagdnim8's Avatar
I'd like to get a tune and the tactrix cable.
I can get the tactrix cable and software for installing the flash directly from you, correct?
Will the software work on an evo ix?
*sorry if this has already been answered in the thread
Old Jun 26, 2006 | 12:04 PM
  #356
DynoFlash's Avatar
Yes you can
I have cables in stock
Also I am working on a soon to be released instruction book to go along with the softwear
I am doing IX's with the E FLASH! also
remember Ecu Flash is what I use to facilitate this product
Thanks
Old Jun 26, 2006 | 12:07 PM
  #357
mike1023's Avatar
Al,
do you recomened us geting the flash from you and then get a log of it some how and then send it back to you for seeing if it all is good? will that be addon money?
Old Jun 26, 2006 | 12:51 PM
  #358
Levar's Avatar
Veteran: Army
Originally Posted by DynoFlash
Yes you can
Thanks
That sounds great Big Al, sir. But I've read through the 350 or so posts without running into the quoted price of purchasing the cable and E-flash as a combo.
Old Jun 26, 2006 | 01:33 PM
  #359
hondafan's Avatar
Al, do you recieve the instruction book included in the 49.99 Eflash!, or is it extra? also, what's your expected release date for the manual? i may wait to order my map until it's available unless i can get it seperate later on.
Old Jun 26, 2006 | 01:51 PM
  #360
cubantexan's Avatar
I am confused now. I thought that the E-Flash was the same as the mail in Dynoflash with the exception that we no longer had to mail our ECU's to Al. I thought the savings in price was overnight shipping/insurance and labor for time spent in comparison to just matching mods to existing tunes he has performed and emailing them to us.
Now I am not so sure as to what he means by ONE map. What do you mean we select our mods, octane, etc...
I thought with the paid $49.99, we supply you with all our mods, octane, and desired boost and you would email all necessary maps required to obtain the same result as the mail in?
What is what?
Please explain and forgive me if I am missing the obvious.
Thanks,
