Pics of my engine bay after some minor work.....
Old Dec 13, 2004 | 04:33 PM
  #46
zstryder's Avatar
Originally Posted by RyongCE
where did you get the charge tube (intercooler pipe) ?
And how much?
I want IT!!!
That's the stock one with some paint on it.
Old Dec 13, 2004 | 04:37 PM
  #47
Evoisdream's Avatar
the paint is in the back by all of the car little things like the cleaning stuff and such and its like 3.75 or something
Old Dec 13, 2004 | 04:39 PM
  #48
zstryder's Avatar
Hm, is that really flat black on the heatshield? It looks so shiny! hahah... I'm guessing the manifold gets too hot to use the same stuff you used on the IC pipe. Did they have the engine temp paint in glass black? I'd like both the pipe and the heat shield to be the same color, if possible.
Old Dec 13, 2004 | 05:29 PM
  #49
MITSU16G's Avatar
I just went out and bought some Dupli-Color high heat 1200 degreese in flat black thats what iam going to use on the heat shield, Did you do anything to prep the heatsheid before painting ?
Old Dec 13, 2004 | 05:44 PM
  #50
rpm-evo's Avatar
very nice, never noticed the Mg symbol with it covered up. Hope the heat shield paint doesn't peel. My valve cover is starting to peel.
Old Dec 13, 2004 | 06:17 PM
  #51
Evoisdream's Avatar
i sanded mine and used the dupli-color 1200 and it bubbled and came off hopefully u have better luck i went and bought the rust-olem stuff and have had it thier for a week and been perfect
Old Dec 13, 2004 | 06:19 PM
  #52
MITSU16G's Avatar
Did this happen to your heat shield or IC piping ?
Old Dec 13, 2004 | 06:43 PM
  #53
Bobby12many's Avatar
Yeah, I grinded it to bare metal with a wire wheel on a drill, then applied three coats about 10 minutes apart.
Old Dec 13, 2004 | 06:48 PM
  #54
MITSU16G's Avatar
How long did that take & how much did the wire wheel attatchment cost?
Old Dec 13, 2004 | 06:53 PM
  #55
Nope.
There is no way teh IC pipe is ever going to get hot enough to boil off. Seeing 500+ degree surface temps is pretty unlikely on that location.
As far as the heatshield goes, I just replaced the bolts holding the heatshield to the mani with SS Allen head bolts and washers which look very nice. The only problem is the fact that one of the bolts sheared off in the mani Now I have a little hole
Still has held up perfect and looks great. Im planning on getting my Manifold ported and ceramic coated soon, so hopefully I can keep this heatshield looking purty even during a track day.
Updated pic with SS bolts: Sorry they are hard to see...
a few pics of my freshly waxed hood
Old Dec 13, 2004 | 06:56 PM
  #56
MITSU16G's Avatar
Sweet cat haha , And abou the throttle wire , did u tape down the plastic that u ziptied the throttle wire to ?
Old Dec 13, 2004 | 06:57 PM
  #57
Took about 20 minutes and a nice vice. Very easy to do. I had a wire wheel laying around that I got at sears for like $1.50
You can get them at any hardware/tool place, cheap.
Old Dec 13, 2004 | 07:00 PM
  #58
MITSU16G's Avatar
You hid the throttle wire well , U tape the wires down that u ziped it to ?
Old Dec 13, 2004 | 07:02 PM
  #59
That plastic is the wire harness that usually sits on top of the valvecover on some clips. I removed all the brackets and clips so that I could finagle it down there pretty securely on its own. I simply ziptied the throttle cable to the harness and then used the little "lift hook" attached to the motor to secure it down behind the valve cover. THere is a single bolt on the littlle hook that allows you to loosen it, and then put the harness behind it, then turn it down and tighten it, securingly it in a little recess between the intake manifold and the head.
Very easy
  #60
nope, thats the factory harness crap
