New headlights on the block
Old Dec 28, 2009 | 03:08 PM
  #31
IXToes's Avatar
Looks great! but I disagree aboout chrome headlights being the sux.... stock black chrome headlights on my IX FTW!!
Old Dec 29, 2009 | 01:03 AM
  #32
iEvoVII's Avatar
More custom headlights added to 1st post
Old Dec 29, 2009 | 01:09 AM
  #33
orugacoja's Avatar
nice job bro
Old May 3, 2010 | 10:46 AM
  #34
iEvoVII's Avatar
Update: 05/04/2010
Added pix of headlights on the car in 1st post for:
- CT9A 5 &
- CT9A 6
Now including pix of previous headlights ive completed + pix of headlights ive completed since CT9A 5 & CT9A 6. ALL for the EvoOZ crew
- CT9A 1
- CT9A 2
- CT9A 3
- CT9A 4
- CT9A 7
- CT9A 8
CT9A 1 & CT9A 2 specs:
- Both housing FULL satin black (No chrome)
- Both with FULL red projectors
- Both with modded light output
CT9A 2
CT9A 3 specs:
- Satin black housing (No chrome)
- Blue projectors
- Modded light output
CT9A 4 specs:
- Parker housing left chrome for the VIIIMR look
- RED projectors
- Light output modded for more BLUE at the edge
CT9A 7 specs:
- Satin black turn signal housing
- Orange indicator piece removed
- Low beam ring left chrome
- High beam ring left chrome
- Foglight ring left chrome
- Full Yellow projectors
CT9A 8 specs:
- 80mm halo ring in Low beam housing
- 100mm halo ring in High beam housing
- Waterproof switch installed behind HL to alternate between Halos & OEM Parkers
- Bottom of Parker housing painted black / Top half left chrome
*Result: semi black, semi chrome look
- BLUE projectors
Video of CT9A 8:
Old May 3, 2010 | 10:54 AM
  #35
CMoney's Avatar
Looks Great. If only you were closer i would have you do mine.
Old May 3, 2010 | 12:01 PM
  #36
OZR_Lancer's Avatar
sweet pix
edit+ same if u were closer id have u do my cedias in satin black
Old May 3, 2010 | 05:01 PM
  #37
4G63kevin's Avatar
looks nice.
Old May 3, 2010 | 05:47 PM
  #38
BriK's Avatar
Sick. As others have said, you should be closer to the US.
Old May 3, 2010 | 08:45 PM
  #39
GG_9_SE's Avatar
This is pretty awesome props to you my friend. Quick question though sorry if it has been asked I must have missed it, but what do you use to seal the lights back up?
Old May 3, 2010 | 09:21 PM
  #40
evilevo2's Avatar
you should put some eurolight to finish up
http://www.myeurolight.com/
Old May 3, 2010 | 11:00 PM
  #41
limp_noodle's Avatar
where'd you get the halo's from?
I want to do that to my car. I have to reopen mine again anyway because I didn't seal them right the first timee. I had to do the oven method because I lent my friend my heat gun. The oven method worked fine for all of my other cars, but for my evo it didn't work as well as I wanted it to.
great job overall man.
Old May 3, 2010 | 11:16 PM
  #42
CJ2X's Avatar
Are you some kind of underground vendor? If so, how much do you charge and turnaround time?
Old May 6, 2010 | 06:49 AM
  #43
iEvoVII's Avatar
All the headlights ive posted are from Australia. why would you even consider me when evodave does headlight in your country..
Im posting this thread so people know what different headlight specs look like on different colored CT9As. Save you from doing any guess work. Glad to give any tech info if needed incase anyone wants to give it a go themselves.
Old May 6, 2010 | 07:16 AM
  #44
ravnos04's Avatar
Originally Posted by ak47po
CF bits=HOT!
Wheels=HOT!
Headlights-Tail lights=Boring.
Really, you don't think the head/tail lights add something extra (for the positive) to the car? I bought my car with them already installed, I don't think I could have purchased an Evo 8/9 without these. The chrome look just looks really ricey to me. Just my .02.
Products look good, keep up the awesome work.
Old May 6, 2010 | 10:04 AM
  #45
iEvoVII's Avatar
I use the OEM adhesive. I just push it back in the groove with a flat head screw driver
Halos I used for this project were from:
gadgetmaster.com.au (Aus business)
I have also bought:
Advance Automotive Concepts halos (US company):
These guys are pricy but their halos are pretty good
Im looking to halos from:
Matt at Theretrofitsource.com (US company) in the next few weeks on a set of Evo X headlights.
CT9A halo dimensions if anyone is interested:
- Low beam housing = 80mm rings
- High beam housing = 100mm rings
- Foglight housing = 70mm rings
