New headlights on the block
Old Dec 2, 2011 | 06:55 AM
  #121
iEvoVII's Avatar
Headlight specs:
* OEM Single Xenon projector replaced with an FX-R BiXenon projector (Low & High beam)
* OEM chrome shroud dremelled away to fit an OEM E46 XENON shroud in the low beam housing
* clear coloured turn signal pieces
* Front half of OEM projector retrofitted in the high beam housing for the "Quad Projector" look only (non functional)
* High beam housing dremelled to fit an E46-R shroud
* Custom aluminium shields painted red and installed to make all projectors look red
On the car
Headlight specs:
* Custom aluminium shields painted Lavender and installed to make all projectors look Lavender in color
Headlights before headlight restoration kit
Headlights after restoration kit:
On the car:
Headlight specs:
* Orange coloured turn signal pieces
* CCFL halos in the Low & High beam housings
* Custom aluminium shields painted Red and installed to make all projectors look Red.
Stay tuned for more
Old Dec 2, 2011 | 07:20 AM
  #122
SRToad4's Avatar
Wow, those purples are nasty. Will be baking mine apart to paint the shields soon!
Old Dec 2, 2011 | 07:31 AM
  #123
iEvoVII's Avatar
^^ just before you open your HLs shoot me an email (in my sig) and ill show you how you can make your light output go from:
* STOCK to
* MODDED
Old Dec 6, 2011 | 03:46 AM
  #124
iEvoVII's Avatar
Some more shots of my mates Blue IX with Quad projectors headlights:
Headlight Specs:
* OEM chrome shroud dremelled away to fit an OEM E46 XENON shroud in the low beam housing then painted silver with the logo painted black.
* This set up is now quad high beam. OEM + FX-R high beam
Old Dec 6, 2011 | 07:39 AM
  #125
llDemonll's Avatar
remind me again why you live so far away?
looks great, are fx-r your favorites (despite bi-xenon) or are they just good and easy to get? tried s2000, tsx, etc before? speaking from a light output / cutoff / ease-of-install
Old Mar 13, 2012 | 01:37 PM
  #126
Sil'vr-Boi6's Avatar
Very nice headlights what hardware do I need to switch factory stanleys lense with TSX or TSX-R lenses?
Old Mar 13, 2012 | 02:38 PM
  #127
rwdeater's Avatar
Nice work
Old Mar 13, 2012 | 02:58 PM
  #128
AWDBus's Avatar
As always, your work is top notch!
Old Mar 13, 2012 | 07:10 PM
  #129
iEvoVII's Avatar
^^ thanks for the kind words
You can't use 2.5" TSX / TSX-R lenses on the factory 3" Stanley projector... It won't fit. There aren't any aftermarket 3" lenses that are suitable for a CT9A projector that I know of...
Old Mar 14, 2012 | 06:23 AM
  #130
Darn. so I guess the only alternatives are to either create a shroud/bezel mold that will fit the 2.5 tsx in a evo healight?
Old Mar 14, 2012 | 07:01 AM
  #131
iEvoVII's Avatar
TSX projectors in a CT9A HL has been done before using the OEM shroud.
* LightWerkz in the US have done this retrofit,
* So have I
The OEM shroud was untouched. There is a gap around the projector when going from OEM 3" to a 2.5" projector
LightWerkz pix:
* Pic 1
* Pic 2
More Pix here
^^ You could paint the lense holder and front half of the projector black so that the silver body is not so obvious through the gap
The TSX/CT9A combo I did, I used a CCFL halo around the OEM shroud which filled in that gap. I dont have pix right now but it should be easy to picture.
OR
If youre a bit more adventurous like me you can hack away at the OEM shroud then retrofit a E46-R (normal version) shroud in its place.. This is what Ive done for the last 3 sets ^^ coz I retrofitted the 2.5" lensed FX-R BiXenon projector...
It requires more work but its a cleaner look and still looks OEM....
Old Mar 14, 2012 | 07:11 AM
  #132
THYBEAST's Avatar
From: ][[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[Woodbridge, NJ
I want to make my evo9 USDM headlights JDM style but I don't know what to use to get the amber signals look good...I've seen them done but the amber is not the right color, does anyone know what to use for the amber? Please Help
Old Mar 14, 2012 | 07:22 AM
  #133
iEvoVII's Avatar
^^ cant help you there boss..... Never worked with USDM HLs
Old Mar 15, 2012 | 06:29 AM
  #134
polish_pounder's Avatar
Were did you get the Xenon projectors? i know my headlights are projectors but i dont think they say Xenon
Old Mar 15, 2012 | 07:39 AM
  #135
llDemonll's Avatar
those are just shrouds that go around the projectors, E46-R shrouds
