My Ongoing Build Thread, Thanks to Force Fed Perf., Spec Ops., MAP, Sparktech, etc...
Old Oct 14, 2010 | 08:55 PM
  #226
06MREvo's Avatar
Originally Posted by Collin@ToxicFab
dang bro, your lucky!!! who made that sweet peace of metal i wish i had one of those!!!
cant wait to see it on the car bj
Some dude in Texas made it for me...can't remember his name...he rocks a purple Tial Q bov though...its cute...haha...
Old Oct 14, 2010 | 08:59 PM
  #227
detroit pistins's Avatar
Old Oct 14, 2010 | 09:05 PM
  #228
ToxicFab's Avatar
Lol purple ftw!!!
Old Oct 15, 2010 | 07:26 PM
  #229
06MREvo's Avatar
Heading to MOD tomorrow....First ever East Coast Mitsubishi Owner's Day in Delaware...Going to be a ton of Evos....should be a great time!! I will be taking a bunch of pics....
Old Oct 17, 2010 | 03:14 PM
  #230
06MREvo's Avatar
My Toxicfab manifold coated by TCC will finally be in my hands tomorrow and I should have my Toxicfab fancy black anodized cam angle sensor heat shield by tomorrow or Tuesday...Testing on the manifold will hopefully be done this week...The tune needs some more work as I've fixed some issues I had with my Tial Q BOV...
Old Oct 17, 2010 | 09:52 PM
  #231
lillev23's Avatar
What were the issues that you were having with the Tial Q, and what did you do to fix them?
Old Oct 18, 2010 | 03:14 PM
  #232
06MREvo's Avatar
I've swapped springs out so many times...11 psi way too stiff...10 psi still a little too stiff but opens late and it causing the car to break up a little once in the higher gear on quick shifts...8 psi WAS too soft...Myself & also CBRD fixed 5 or so boost/vacuum leaks I had...I had also the 3/16 bov line T-ed into twice...once because that is where my stock boost gauge was T-ed into from the factory and the other was my MBC since my Buschur Racing J pipe didn't have a nipple on it for the MBC...I pulled the j pipe off and drilled a hole in it and had a buddy at work weld a bung on and I threaded a brass nipple in and used the white high temp thread sealant on it, pretty much looks exactly like Brian aka Most-Wanted did on his....So now the BOV has its own 1/4" line straight to the manifold...I also T-ed the boost gauge line into the FPR vacuum...The tune needs/will need a little work once I get the Toxicfab manifold on and before the event at Englishtown this weekend, since I was going to enter the stock appearing class....
Old Oct 19, 2010 | 12:11 PM
  #233
850RCT9A's Avatar
You going to be at import faceoff in Reyolds, ga nov 7th?
Old Oct 19, 2010 | 02:38 PM
  #234
06MREvo's Avatar
Update on this...I finally got a hold of the Tialsport guy on here and he told me it was alright to shim the 8 psi spring some to get it to work better...10 psi spring is just a bit too stiff...so ill be doing that tonight/tomorrow...
Also I finally got my Toxicfab manifold!!! I know most of you guys have seen pics in his thread but ill still post some pics later...
Old Oct 19, 2010 | 02:39 PM
  #235
06MREvo's Avatar
If I still lived in NC I would but I live in NJ now...
Old Oct 19, 2010 | 04:00 PM
  #236
lillev23's Avatar
When you say the Tial was opening too late, was it running rich or idling high along with the late opening?
Old Oct 19, 2010 | 05:05 PM
  #237
06MREvo's Avatar
Car isn't really idling high....idle a/f is all over the place...and wot a/f is rich as hell too...
Old Oct 19, 2010 | 05:10 PM
  #238
lillev23's Avatar
I was talking about like in between your shifts. When you go to mash the clutch in and go to the next gear, would it go rich sometimes? I think I might have been having some of the same problems with my Tial. Might have to change my spring also
Old Oct 19, 2010 | 05:25 PM
  #239
06MREvo's Avatar
ooo ok...honestly I can't really remember but I think it was...You have the Tial QR right? I am assuming they use the same springs as the Q? What spring do you have in there now?
Old Oct 19, 2010 | 09:16 PM
  #240
lillev23's Avatar
I think I have the 6 psi spring. Not really sure though. I'll go out and check tomorrow.
