EvoM's First Wire Tuck How To
Old Jun 11, 2012 | 10:19 AM
  #46
R/TErnie's Avatar
Thanks for sharing. I just went through my wiring harness and re-routed the groupings. pain in the butt! Now I want to completely re-do the harness from the ECU. I hate seeing things that I want to change.
Old Jun 11, 2012 | 10:50 AM
  #47
Blue91lx's Avatar
No problem .
It surely is a pain. I had the same thoughts afterwords. It was such a mess under there from the factory. In the future, I would love to do the entire harness if I suddenly grow the cojonés.
Old Jun 11, 2012 | 11:02 AM
  #48
R/TErnie's Avatar
Originally Posted by Blue91lx
No problem .
I'm stocking up on 20 and 22 awg multicolored silver stranded Tefzel wire for a reason I know I can save a few pounds with the ACD wiring that goes 7 feet and then turns back on itself and goes to the back of the car. Probably needs 10 feet of wire, but has more like 24 feet. The PDC being located in the heaviest corner of the car is also not the best idea. I'd like to move the PDC under the dash if possible... or maybe go to a MoteC PDM and hide that ish.
Old Jun 11, 2012 | 04:22 PM
  #49
Blue91lx's Avatar
Heck yeah! I'm sure so much efficiency is lost in how long and how unnecessarily twisted all of the harnesses are from the factory. Save some for me .
And agreed. Under the dash would be incredible. I REALLY need to get a DD so I can do some more intensive wiring work to my car.
Old Jun 17, 2012 | 09:16 PM
  #50
okevolutionVIII's Avatar
This thread was posted at a great time for me. After spending a month tracking down why I have no spark or fuel, I started un-looming the same part of the harness you did a few hours ago looking for broken or melted wires. Would be a perfect time to clean everything up and remove the EGR connectors.
Old Jun 18, 2012 | 12:20 PM
  #51
Blue91lx's Avatar
Well, I'm extremely glad you found this useful, as that's why I posted it!
The only tip I have for you is to make sure when removing the EGR plugs that you don't accidentally remove the plug for your knock sensor, which looks very similar to that of a coil pack.
Good luck!!
Old Jun 26, 2012 | 08:18 AM
  #52
OverBoostedEvo's Avatar
looks good. i'll be doing this as well except i'll be depining the connectors and running all new wire all in black and hiding the fusebox inside the car. gonna take me a while but will be worth it in the end. im going to try to remember to take pictures and i'll add them here as well to add to ur writeup. I'm also going to try to hide the radiator, delete power steering, ac, and abs. i want the minimal amount of things in the bay, basically if i dont need it it wont be in it.
Old Jun 26, 2012 | 10:31 AM
  #53
Blue91lx's Avatar
Awesome, mang! If you did a writeup on the fuse box relocation I think that would be a great asset to the community.
I didn't want to delete anything, as the car is purely a street car so weight isn't really an issue to me. Any reason why you want to hide the rad?
Old Jun 26, 2012 | 10:33 AM
  #54
i figure since im doing a change of color and a complete rebuilt on the car i mise well try to hide as much as possible, plus it will give me more room to work with for my turbo setup
Old Jun 26, 2012 | 11:03 AM
  #55
Blue91lx's Avatar
I agree with you there. My chunky Koyo makes me a bit frustrated at times. BTW, saw your build over on Tristate. I'm the same Blue91lx over there .
Old Jun 27, 2012 | 04:03 PM
  #56
ihockey1's Avatar
so im holding the three egr wires you cut out, was the one with the thick green cable a grey plug that used to go by the back left side of the valve cover? just wondering because i did the egr delete but that grey plug was still plugged in so im not sure if i should cut it out, but if i can i will
Old Jun 27, 2012 | 05:36 PM
  #57
Blue91lx's Avatar
That was my fault for not editing that. I posted about that above. That grey plug is for your knock sensor, which I ended up putting it back into the harness.
Old Jun 27, 2012 | 06:26 PM
  #58
FenixTX717's Avatar
Props to you man, that is something I would never have the patients of doing!
Old Jun 27, 2012 | 06:28 PM
  #59
ihockey1's Avatar
hahaha good thing i asked lol
Old Jun 27, 2012 | 06:31 PM
  #60
Blue91lx's Avatar
Indeed. I'm going to edit that picture now.
