Evo VIII Build in The Mitten State
Car looks amazing man! I do like the SE lip and OEM side skirts better though, but the Voltex is def something different and still looks pretty good. What is size and offset of your rims? I'm liking how the car sits
So I know I posted a bit about the KW coilovers previously, but I just wrote a review for OctaneFreaks.com through Modified and figured I would post it up here as well. I'll include a link when it gets posted on the site, but here's an early preview!
KW Variant 3 Coilover Review: 2003 Mitsubishi Lancer Evolution VIII
After purchasing my relatively stock Evo last November, I found that the overall ride quality and height of the car left a lot to be desired. The car was equipped with a set of lowering springs paired with the factory struts, and though the Evo is plenty capable in stock form, I wanted a suspension setup that I could utilize for daily driving and occasional track duty while allowing me to dial in the car’s ride height.
Needless to say, I was immediately drawn to the offerings available for the chassis from KW Suspensions. When you think of high-end coilovers with a great track record (pun intended) and exceptional ride quality, KW is usually one of the first to come to mind. Regardless of whether you drive an American, German, or Japanese car, KW offers a wide range of setups to fit your specific need and budget.
Knowing that my Evo is going to see hundreds of street miles each week on the way to and from the office, I chose to go with the KW Variant 3 for my application. The Variant 3 is a great option for someone that drives their car frequently on the street and wants to be able to adjust their ride height, but also wants to be able to hit the track or an autocross event on the weekend from time to time. The great thing about the V3s is that they allow independent adjustment of rebound and compression, allowing you to maintain a comfortable ride for everyday cruising and turn it up a notch at the track with the twist of a knob or two.
After a short wait, my coilovers arrived from the warehouse in California. Upon opening the box, I was immediately impressed with the quality and presentation of the materials. It’s clear that no corners are cut with packaging or the construction of the suspension itself. A small plastic KW case was included that housed the tools required for adjustment of the coilovers, instructions, and a few stickers- always a pleasant surprise!
One thing to note about the KW Variant 3 coilovers for the Evo VIII/IX application is that they do not include top hats/strut mounts. This allows the user to decide if they would like to reuse their factory components or opt for aftermarket top hats with more adjustability. I chose to go with a pair of Cusco pillow ball top hats for the front and brand new OEM top hat components for the rear. Utilizing the factory top hats is a part of the secret to a comfortable ride, but I chose the Cusco mounts up front for their added camber adjustment- not to mention the fact that they look great under the hood! With the Evo VIII chassis continuing to age, I figured that replacing all of the rear suspension mount components while I had things apart would be a good idea.
Installation of the coilovers was really straightforward, and I was able to complete the task in my garage with hand tools. One thing I noticed while installing the front suspension is that KW includes their own eccentric bolt setup for the top bolt on the front coilovers, allowing for a bit more camber adjustment than the factory bolt does. Pretty nice touch!
After about 2.5 hours, I had the car back on the ground. This meant it was time for my least favorite part of an install like this- adjusting the ride height. The coilovers were set pretty high initially, so I brought them down quite a bit. The front can go about 3-4 turns lower and the rear can go a substantial amount lower if desired, but I chose to keep things at a street-friendly height.
I was extremely impressed with the way height is adjusted on the KWs. I actually didn't even need the included adjustment wrench- the lower collar turned so smoothly and easily that I was able to do it by hand! A welcome change from any of the previous coilovers I have owned. The collars have a tiny grub screw in them to tighten after adjustments are made to ensure your settings stay where you want them. This setup should really help to prevent those pesky frozen collars that have plagued me with previous setups.
I chose the KW's for their handling capabilities, so I was content with a more sensible ride height this time around. My previous S13 build looked great, but it really wasn't possible to drive the car aggressively through corners with the ride height and wheels specs I chose for it. I'm happy I changed things up a bit with this car so that I can still enjoy spirited driving without having any rubbing or alignment issues.
I decided to leave the compression and rebound settings as they were set from the factory based on KW's recommendation for the Evo, and they seem to be set up pretty well all around. The ride is definitely firm, but it isn’t extremely harsh or rough. There isn't any bounciness over bumps like I was used to with lower end coilovers on my S13, which is a really nice change. I would probably attribute some of this to the included helper springs. The car stays on track and compliant through rough roads, and feels a bit flatter when cornering than it was with the previous lowering spring setup.
Overall, I couldn’t be happier with the way the car looks and drives after installing the KW Variant 3 coilovers. I’m looking forward to getting out to some track events this summer to see what they can really do!
Thanks guys!
I installed my Voltex rear diffuser last Friday and spent some time with the clay bar getting the car all cleaned up for a local concourse show called Eyes On Design. It was pretty painful hacking up a brand new and very expensive piece of fiberglass, but it paid off in the end. This is the only picture I took during the process:
I had to remove a good amount of material from the diffuser to clear my Tomei exhaust. I love the look of the diffuser though! I think it really completes the look and the car doesn't feel off balance visually to me anymore. I was thinking I would need to remove the factory wing, but I actually kind of like it on there with the Voltex goods. I will be adding a Voltex wing in the near future though- hopefully in about a month's time or so.
Some snaps at Eyes on Design:
Random pics after the show. I also installed my OEM window visors:
So yeah, pretty happy with the exterior at this point. I've got a pair of Ganador mirrors to take in to paint, but I'd like to wait until my OEM vortex generator is here so that I can paint both items at once. I think once the mirrors, vortex generator, and wing are on I'll be content with the exterior. At least I hope so! lol. Who knows with me though...
From: Detroit metro area Michigan/Washington DC metro area
this car has come a LONG WAY CHEERS to you sir for building a very classy piece of mechanical artwork! i am glad i am subscribed and will continue to follow this as far as it goes! BTW my TB VIII and my self move to royal oak area in early august, are there any FB groups up there for evos? if not maybe we should start one. the EVO scene in dc exploded once we had a group to post to. now if some one has a install day or cook out instead of 2 or 3 people we get 15 to 25 evos some times more. LMK I look forward to seeing this car in person ! and i never thought i would see a R34 riding around michigan considering the opinions up there about imports ;-)
OP, keep up the good work. I'd love to see your car in person and maybe a photoshoot with my Varis Evo.
haha! Nahh. Most of the ARC goodies left town to fund other stuff.
It was not a fun experience, haha.
Thanks! Everything definitely flows a lot better now.
Nice! I believe there is a "MI Evo" FB group that is a subset of the forum MIEvo.net and there is also a "Michigan Evo Owner's Group" on there. The main forum for these kinds of cars in general out here is XceedSpeed.com. I'm sure we will cross paths at some point for sure!
Thanks a lot!
I definitely liked that look as well. I'll be rocking the SE lip with stock side skirts and JDM rear in the winter months, so that look will make a come back for about 5 months or so each year. I had originally intended to stop there, but I got sucked into the Voltex aero.
lol, thanks PT! I know it's not for everyone, but I am super pleased with how the car looks right now. Hopefully we can get out to the track at some point this season!
Sounds awesome! I love the Varis aero. I'd love to check it out sometime!
Thanks a lot!
